PornoSatan
- Sep 3, 2004
50$ is all I'm willing to (and can for that matter) spend on a decent pair of headphones. Preferably with a jack straight into the soundcard. I dont need a mic, but I wouldnt mind if it came with one.
Looking for sound quality thats better than the headphones that come with a typical CD Player. Which is what I'm currently using basically at the moment.
Advice I dont need:
"If you're willing to spend xx more dollars you can get the really awesome xx model"
Advice I do need:
Some examples within my price range.
A good example between the differences of a "good" pair of headphones and a "bad" pair. What specs matter? Any recommended URL's to learn more? etc.
Thanks.
Advice I dont need:
Advice I do need:
Thanks.
