Astral Abyss
- Jun 15, 2004
In light of all the issues people are reporting with running 4 sticks of RAM, I just wanted to post that I'm having 0 problems with my EVGA 650i Ultra and 4 sticks of G.Skill F2-6400CL4D-2GBHK (800MHz).
(See my sig for full system specs)
I'm currently running my 4300 @ 350MHz x 9 = 3.15GHz, unlinked, with the RAM @ 800MHz. CAS is 4-4-3-10-2T. 2.0 volts. Stable in my favorite memory testing program... World of Warcraft (I ran Orthos also, but World of Warcraft is more picky about RAM than any other program I've used)
I didn't even need to increase any voltages for north or southbridge. They're both still at stock 1.2v.
One important thing I did was add airflow to the RAM. Before I added the 2nd pair of 1GB modules, I did the "finger test" and found out my RAM was getting very hot while testing and gaming. I purchsed the Corsair Dominator fan unit to place over all 4 sticks of RAM. If the RAM was getting hot with 2 sticks... 4 would be worse. By the way, the fan unit was simple to install and looks pretty cool mounted. It's a tiny, tiny bit noisy at 100%, but if you bump it down just a tad it's silent. Works great too, which is the most important part. RAM is now only warm to the touch. I'm absolutely positive that without this fan cooling the RAM, I would be having stability issues. (I wonder how many people have no idea their RAM is cooking itself because they think they have good airflow (like I did) ).
So basically I just wanted to point out in this post that 4x1GB is doable and stable on the 650i Ultra if you use decent RAM and keep it cool. I think CAS 4-4-3-10 is pretty impressive with 4x1GB @ 800MHz, 2.0v and no other related voltage increases necessary... even more impressive after hearing people rip on the Nvidia memory controller.
I'm going to attempt to OC a bit this weekend and see what happens... more to come.
