I tried running the Hitatchi WinDFT tool to erase the whole drive (took hours) and the MBR (even though it is a GPT disk). The Hitatchi tool says the drive is 4TB in one window and then in the next it says it is 3TB. Disk management, diskpart, and Testdisk all say the drive is 1678GB (the entire drive not just a partition). Now I have also had problems when I connected this drive to a PC I had to reflash the EFI to get it to start up again. I think the problem was when this drive was connected to a Rosewill dock that only supports 3TB drives, not 4TB. Problem is that I can't get the drive to work as 4TB again no matter what I do. The drive was directly connected using SATA for all this troubleshooting, none of this usb dock business. Any suggestions on what's going on here???
PS this may also be happening to a 4TB Seagate drive that was incorrectly used with the same dock. Still investigating that.
