4k/60Hz HTPC Build
Discussion in 'Home Theater PCs & Equipment' started by Nevalite, Sep 8, 2018.
  1. Nevalite
    Nevalite Limp Gawd
    221
    Feb 6, 2006
    Hi Everyone,
    So I am in the process of putting together a parts list for a new HTPC. The goal is to make a future proof HTPC which can do the following:
    • 4k @ 60Hz (HDMI 2.0 needed)
    • HDCP 2.2 compatible (netflix 4k streaming)
    • HDR
    • Onboard graphics
    • Quiet
    • mITX form factor (small)
    • Budget $500-600
    • Ideally play UHD Blu-rays from an optical drive
    None of the current intel CPUs (except Gemini Lake) handle HDMI 2.0 from the onboard graphics so I decided to return to my old roots and build and AMD system. Most of the Intel boards convert the DP to HDMI 2.0 via an LSPCON chip which has given many people headaches. The Ryzen 2400G seems to be the ideal candidate for an HTPC with the built in Vega 11 GPU. The Ryzen 2400G supports HDMI 2.0 on most of the current motherboards so that is a huge plus. The one major drawback from the AMD cpu is that it seems the DRM for UHD Blu-ray playback only works with the Kaby Lake Intel CPUs, I will probably pass on this requirement.
    Here is what I have come up with:
    CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor ($159.99 @ Newegg)
    Motherboard: ASRock - B450 GAMING-ITX/AC Mini ITX AM4 Motherboard ($123.98 @ Newegg)
    Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory ($100.98 @ Newegg)
    Storage: Samsung - 970 Evo 250GB M.2-2280 Solid State Drive ($99.88 @ Newegg)
    Case: Fractal Design - Core 500 Mini ITX Desktop Case ($60.84 @ Newegg)
    Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ Newegg)
    Optical Drive: LG - WH14NS40 Blu-Ray/DVD/CD Writer ($60.98 @ Newegg)
    Total: $676.64
    In this build I have dropped UHD blu-ray and just put a regular Blu-ray drive. The PSU may be overkill but I am a big Seasonic fan, I may drop it down to a 550W.
    My questions:
    1. Will this build support HDCP 2.2? Does Ryzen 2400G support it now?
    2. Is it true that you need Kaby Lake for UHD?
    3. Do you have any other suggestions?
    Thanks for any feedback!
  2. sinisterDei
    sinisterDei Gawd
    825
    Dec 1, 2004
    So, I'm not going to answer most of this, I'm just gonna speak to one particular topic: HDR support
    HDR support on PC is balls. For PC use, you probably want 4K@60Hz@4:4:4 chroma subsampling. In order to get the HDR though, you have to drop to 4:2:2 or lower chroma, and toggle the switch in Windows for HDR mode on Win10. Unfortunately, this is a manual button-press and not something your media playback software can press for you on an as-needed basis, and playing back SDR content when in HDR mode is less ideal thanks to the chroma subsampling and shitty weird behaviors by Windows in general.
    If you just want to play back media, seriously, just buy a Shield. I say this as someone who owns a HTPC. If you aren't going to couch surf the internet a lot, or play games a lot, then a standard thick HTPC isn't really needed anymore and a Shield will handle all the media playback you like. For optical playback, well, you're on your own for that, but it's likely a small percentage of your use so maybe just buy a standalone BD player the day that problem comes.
  3. lightsout
    lightsout Gawd
    634
    Mar 15, 2014
  4. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    8,206
    Jun 13, 2003
    Yup. Because this is true:
    I don't know why it's true, but I can confirm it. This is why I haven't been very excited about HDR on the desktop and an HTPC is unfortunately no different. I really don't know why it's still a bit of a mess but it is.
    All while my Shield works great.
  5. Onknight
    Onknight n00b
    4
    Oct 13, 2018
    my TV don't have HDR and Find the need for it
    so I am going ahead with PC Build Just want 4K
    I had Android they are throw away boxes even the shield .
  6. sinisterDei
    sinisterDei Gawd
    825
    Dec 1, 2004
    A device released in 2015 that's received continual updates and support for 3 years isn't a throw-away device.
  7. MrGuvernment
    MrGuvernment [H]ard as it Gets
    19,140
    Aug 3, 2004
    NVIDIA shield and just rip your blurays to a network device and share off NFS and be done with it.
  8. MrGuvernment
    19,140
    Aug 3, 2004
    Shield is not a throw away box and is the only device to support i beleive 4k 60FPS, while nothing in the PC market does for video
  9. sinisterDei
    sinisterDei Gawd
    825
    Dec 1, 2004
    Er, I'm a big proponent of the Shield here, but PCs can definitely play 4K content @ 60FPS. Not that there is a ton of 4K60 content out there, but there's a bit on Youtube and it plays fine.
  10. Trimlock
    Trimlock [H]ardForum Junkie
    15,122
    Sep 23, 2005
    I think what is getting blurred here is that the shield will do 4k content extremely well and is also VERY cheap when compared to a PC that can.
    There is now a few other products that can also do 4k content to the TV but I believe the Shield is still the cheapest? I haven't looked into it in a while.
    Actually at this point I'd only consider the Roku Ultra or the Apple TV 4K
  11. sinisterDei
    sinisterDei Gawd
    825
    Dec 1, 2004
    As the guy who originally suggested the Shield in this thread, I don't think I'm missing that point. I've advocated for the Shield as a 4K content player in this thread since the very first response. WIth that said, these are separate arguments and the bit you quoted me saying was in direct response to:
    And that is factually untrue. You can argue about the Shield/Roku/Chromecast Ultra/Apple TV whatever being a better value fo 4k60, or easier to use, to your heart's content, but you can't make the argument that the PC (or other platforms) doesn't support it because they do.
  12. MrGuvernment
    19,140
    Aug 3, 2004
    Mmmmm, perhaps i am confusing something then, when i got my shield it was the only thing that could do 4k/60FPS, and is it HDMI 2.0? or 2.1? where as nothing in the PC market had 2.0 or 2.1 HDMI?
  13. sinisterDei
    sinisterDei Gawd
    825
    Dec 1, 2004
    No clue. The GTX 900 series was contemporary to the release of the Shield, and has HDMI 2.0 and 4k60 support, so my guess is confusion :) Plus, I wouldn't put it past Nvidia's marketing to pitch themselves as the only set-top box to support 4k60, which they very well may have been at that time.
  14. DahlKen
    DahlKen [H]Lite
    103
    Feb 1, 2012
    Having both a Shield Pro and a dedicated HTPC I would enthusiastically recommend the Shield. I have even been debating upgrading the HTPC and weighing the pros/cons of just replacing it with another Shield and designate the HTPC to fileserver.
    IdiotInCharge likes this.
  15. IdiotInCharge
    8,206
    Jun 13, 2003
    Yup.
    Until there's say a Linux distro that can actually do the HTPC thing, which the Shield Pro arguably already is (!!!), then I don't really see the need to fix what isn't broke. Which reminds me that I need to get my wireless keyboard/touchpad hooked up to it...
  16. Trimlock
    15,122
    Sep 23, 2005
    My HTPC is still spare parts, if I ever needed to upgrade it I’d probably throw it away.
  17. MrGuvernment
    19,140
    Aug 3, 2004
    Thats how i went, QNAP to host all my content and the shield in the living room. I have 2 Dell SFF's in my basement and one in the bedroom, bedroom runs win 10 and basement is Ubuntu. I had kodi linux for a while but i liked just having a desktop OS to do other things on.
  18. Nevalite
    Nevalite Limp Gawd
    221
    Feb 6, 2006
    Went with the advice from the thread and got a Shield, absolutely loving it so far. The GeforceNow cloud gaming service is a real nice bonus feature. Just need to get my NAS setup finalized to test out Kodi on this little beauty.
  19. MrGuvernment
    19,140
    Aug 3, 2004
