I have an ATI Express 3200 motherboard with 4x1GB of OCZ Platinum PC3200.
My ram won't run at 200Mhz unless I have only two of my DIMMS installed. With 3 or more, it only runs at 100Mhz.
I knew there were some problems with the earlier A64's and larger amounts of RAM where the speed was reduced but I didn't know the Toldeo core X2s had the same issue.
I manually set the memory speed in BIOS and reduced command rate to 2T but that does not change anything.
Anybody share the same experience? Do the C2Ds have this issue?
Thanks,
C
Thanks,
C
