First off this is the first time ive installed a 3rd party cooler to a video card.
So please bear with me
I got 2 power colors 4850 coming UPS today and i plan on crossfirein them on a GIGA-X38 mobo. My plan is to hopefully have Accelero S1 Coolers on both of them.
Here are my questions-
1. Will the crossfire connections connect with the S1
2. Is the stock cooler on the 4850 the same as the 3850, the reason being according to Acceleros website -http://www.arctic-cooling.com/vga2.php?idx=147&data=7&disc=
"Only remove 4 screws located at the center of the back side of the card. Keep the pre-installed RAM heatsink and Voltage regulator heatsink without remove them."
Thats the install tips for the 3850, so according to that i should keep the factory installed ram heatsink/voltage.
So if the 4850 has the same cooler i should keep the factory installed ram/vol heatsink correct.
Any help would greatly be appreciated.
Thank you
Thank you
