48 port gigabit/8 port POE switch
Easius
Need to replace end of life layer 2 switches, and currently need about 30 gigabit ports + 8 gigabit PoE ports.
Looking for a reasonably priced 48 port switch with at least 8 PoE ports... the other option is I just use 2 switches, but I'd rather just do this with 1 (But 48 port PoE switches are pricey!)
Any suggestions?
Thank you
goodcooper
you won't find one like that
maybe a 48 with 24 poe ports...
what's your budget?
m1abram
What about using a stackable switch and get one variant that has POE
Xipher
Juniper's EX3200 and EX4200 non-POE versions do include 8 PoE ports.
D-EJ915
The Cisco SMB SG200 50-port gigabit POE has only POE on the left half of the ports...
Considering it coughed up its config before that client got their own full-time IT guy so I stopped having to deal with it I would suggest to avoid it though.
Easius
Everyone recommending layer 3 when I said layer 2 :)
Thanks for the info though guys. Budget is <$1k.
2 switches seem like the best choice. I'd go with a 48port POE but honestly they only need 6 POE and we don't see the need for more growing over the next few years.
