I'm building a mini-ITX PC for a software router / NAS / WAP combo and am having a hard time finding a quality low wattage power supply. I need something that is small and would preferably fit in a decent mini-ITX case. I would prefer to pay for quality as I hope to have this last from five to ten years if possible.
I don't plan on doing any over clocking and this unit will only ever be using the CPU as a GPU as if I want to get a second computer I'll build a proper HTPC.
According to Part Picker I'm looking at under 130W for the system: http://pcpartpicker.com/p/Hd4sgs
Does anyone have any suggestions? If you could suggest a case that would go with it as well that would be a bonus, thanks! I'm would prefer one that lays horizontal.
