Anyone using this TV as a monitor getting upgrade-itis for the curved 43" UN43KU7500 ?![]()
None, I don't think there would be any real benefit.
If it was IPS I would be all over it, but it's not so no.Anyone using this TV as a monitor getting upgrade-itis for the curved 43" UN43KU7500 ?![]()
My 43KU7500 arrives today and I'll be able to compare to the 40KU6290 I got for my wife around Black Friday for $290. While I'm pretty sure its not worth upgrading if you already have the KU6290, I was kicking myself for months that I didn't get a 2nd or 3rd one or one for every room since it was a steal at $290, so the KU7500 while more expensive, also seems to be a nice upgrade which made it worth it for me.
Ive had both, definitely wouldnt go back to the 6290. Someone who just has the 6290 and never sees the 7500 would be happy though as it is an excellent monitor IMO.
Good to hear. I'll be getting my 7500 Thursday, but I need to find a new GPU to put in my PC that supports 4K. Would like to get a 1060 or 480/580 for $200 or less if possible. There's a EVGA 1060 SSC for $200 in FS/FT right now.. might jump on that soon before someone else does. I plan on running my games at 1080p still on this TV an hoping it still looks good.
I was just thinking about my personal monitor purchases over the last dozen years. In 2005 I spent $300 on a 17" 4x3 monitor and used that until 2010 when I purchased a $200 27" Asus. That monitor still works and was just replaced with this unit. 17" to 27" to 40" ... how much larger can you go and still call it a "monitor"?
I have the 6290 with an EVGA 1060 SSC Gaming (6GB) and works great. I don't game as I don't have time but have let the kids play some stuff from my steam library and haven't had any issues.
While I'm on the subject...anyone experience any "no signal source" on bootup? I know it's not the cable. If I let it go, the pc will reboot and all come back fine. Bizarre.
If you're talking about the POST screens, that's because it doesn't support the resolution that is outputted during that sequence (640x480 I think is still the standard). If you need to get into your BIOS you'll need to plug in another monitor.
I'll check it when I get home but it doesn't happen everytime. It's about 50% of the time. Sometimes it boots just like it should. And it ALWAYS boot correctly when it decides to reboot itself.
That sounds more like an issue with the PC than it does with the TV. I would hook up a second monitor to it so I could watch it POST so I could see what's going on when that happens. Most likely it's booting into a recovery menu or something like that for some reason and it's timing out and rebooting normally after that. Then hopefully you can see what's causing it and go from there.
I have no issues with bios display with this screen. It supports lower resolutions just fine.
this tv has been one huge pain in the D anyone else experiencing intermediate blackscreens with sound and the hud is still visible?
^but this is through the cable connection... just chatted with sammy support and got the new 1180 firmware for this model.
