So, per my sig, I have 4x GTX 680 Classified's. On my main card I'm using every port for my main three monitors.
24" 29" 24"
I use the sli option max performance.
I purchased a long HDMI cable, that I want to run to my tv, for certain games.
I plugged my hdmi cable into card 2, but the only way I can get it to display is to disable SLI.
Is there any way to disable monitors 1-3, and enable the TV, with SLI without unplugging my monitors each time? ( moving this case is quite the challenge... )
EDIT:
ok, card 3 works, it allows me to switch between the tv, and all three monitors and keep SLI.
Thanks
24" 29" 24"
EDIT:
Thanks
