thanks for ur recommendationJust get another mobo that has 2 pcie slots, no sli needed and get a cheap GFX card like an 8600gt and your good to go
which mobo should i get that is better than what I currently have? I don't want to spend money on a mobo that is a downgrade to what I have now.yeah what jvz said if you want to keep it cheap as possible. $70-100 for a mobo and another $50 for a video card (multiply by ~2/3 if you buy used) and youre set. another option is to find a 4850x2 for ~250 new, ~150 used. it has 4 dvi ports, 2 for each 4850. and you can easily turn on xfire to make both 4850s run only 2 of the ports, which is great for gaming. thats what i have an i love it. got mine for $150 shipped off the forums a few months ago. just another option if you want to keep you motherboard and spend that extra money upgrading. or HD5XXX if 3 monitors will do.
