3U Supermicro Storage Server with 8 Core opteron, 64GB ECC Ram, 128gb SSD
dm3
Sadly, I'm parting with my Supermicro 3U Server. It can serve as a great FreeNAS, unRAID, or Windows Server Storage box. Works Bring your own drives, and controller, comes with everything else:
Supermicro SuperChassis 836A-R1200B
Supermicro H8SGL-F Motherboard
Dual Intel NICs onboard
1200W Dual Redundant GOLD power supplies
2.8 GHz Eight-Core AMD Opteron 6320
64 GB PC3-12800 1600Mhz DDR3 ECC Registered DIMM
Slim 8x DVD-RW / 24x CDR Combo (SATA)
128GB Crucial M4 SSD
Quick Release Supermicro Mounting Rails (MCP-290-00053-0N)
16 x 3.5" hot swap mounting trays on a SATA/SAS backplane. Takes 4 x SFF-8087 connectors.
Supermicro IPMI
Listing on:
SUPERMICRO 3U Storage Server 2.8ghz 8-Core Cpu, 64GB ECC Ram, 16 Bay , SSD 2xPSU
dm3
On the scale of rackmount servers it is quite tame in terms of noise level. Compared to a desktop machine it is certainly on the noisier side. That being said, this chassis takes standard 80mm 4-pin PWM fans, and the AMD G34 cpu heat sink mount is compatible with AM3 heatsinks. With a little bit of modding this could be turned into a fairly quiet machine. There are some youtube videos out there on modding supermicro chassis to near silent levels.
