I downloaded 3dmark2003 to run a test on my computer, and I got 1478 as a score. When I checked online, people online that it matched me up with had scores in the 5000s... Here are my system specs:
AMD Athlon XP 3000+
Radeon 9800 PRO 256MB
512 RAM PC 2700 (not perfectly sure of PC num)
Realtek built-in mobo sound
2 gig pagefile size
37 gig HD with 26 gigs open
Windows XP
I haven't OCed anything, and didn't have any background applications running... Is this a normal score, or do I need to question my computer provider?
EDIT: I also upgraded all my drivers via Windows Update and the Driver pages for the components... I'm using Catalyst 4.6. I also had "semi-formatted" my computer by using their restore service, because when I called HP service up about a driver issue I was having, they told me I would "lose all support and likely your warranty" if I deleted the main partition and created a new one.
AMD Athlon XP 3000+
2 gig pagefile size
Windows XP
