Is this setup of devices on vlan 63 going to have to talk to the rest of the network or are these devices all going to reside on this specific switch? If they need to be able to communicate data outside of the switch you are playing around on, then you will need to configure your uplink port on this switch to be a trunk port, otherwise the only traffic that will pass is (by default) vlan 1. I assume that your vlan1 is your native traffic/internet access vlan and that vlan 63 is setup for communicating/receiving data from the sensors.
the initial testing between both (Vlan 1 and Vlan 63) are on the same switch; the reader devices on Vlan63 (10.10.63.2 and 3 - 10.10.63.1) connected to ports 5 & 6 configured will be routing UDP/IP traffic to Vlan 1(128.1.1.100 - 128.1.1.161) configured for port #10 on the same L3 switch.
The next phase Vlan 63 will reamin as is although Vlan 1 will be configured as an the uplink allowing the reader devices to forward their (TCP or UDP frame/packets) traffic up to the app server, which will need to be routed through a series of switches and routers within the network.
