3750x L3 Switch configuration Issue(s)
Discussion in 'Networking & Security' started by bill2455, Jul 3, 2013.
  1. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    I have RFID Reader (10.10.63.2 - 255.255.255.240) connected Cat-6 POE to ws-c3750x-24p-s - standard TCP/IP web service app pulling data from the reader every 250msec:
    I have my app server connect via vlan by ws-c3750x-24p-s IP address (128.1.70.1 - 255.255.0.0) as you can see its on a different subnet;
    I can ping the device from the server - although I'm not getting any data coming through:
    my config are as:
    0 [switch 1 provision ws-c3750x-24p-s]
    1 [system mtu routing 1500]
    2 [ip routing]
    3 [no ip domain-lookup]
    4 [vtp mode transparent]
    5 [crypto pki trustpoint TP-self-signed-1218624768]
    6 [enrollment selfsigned]
    7 [subject-name cn=IOS-Self-Signed-Certificate-1218624768]
    8 [revocation-check none]
    9 [rsakeypair TP-self-signed-1218624768!!]
    10 [crypto pki certificate chain TP-self-signed-1218624768]
    11 [certificate self-signed 01]
    Vlan; [vlan 63] Name; [**reader!!!]
    12[interface FastEthernet]
    13[no ip address]
    14[no ip route-cache cef]
    15[no ip route-cache]
    16[no ip mroute-cache
    for parts 5 and 6:
    Port#5 [interface GigabitEthernet1/0/5 switchport access vlan 63 switchport mode access !]
    Port#6 [interface GigabitEthernet1/0/6 switchport access vlan 63 switchport mode access!]
    17 [spanning-tree mode pvst]
    18 [spanning-tree portfast default]
    19 [spanning-tree extend system-id!!!!]
    20 [vlan internal allocation policy ascending!]
    21 [vlan 63 name **reader!!!]
    22 [interface FastEthernet0]
    23 [switchport mode access]
    4th line:
    1 [interface Vlan1]
    2 [ip address 128.1.1.161 255.255.0.0!] (switch IP address?)
    3 [ntp server 128.1.20.20]
    4 [interface Vlan63]
    4a[ip address 10.10.63.1 255.255.255.0!]
    5 [classless]
    6 [ip classless]
    7 [ip http server]
    8 [ip http secure-server!]
    9 [ip sla enable reaction-alerts]
    9a [logging trap notifications!]
    10 [line con 0]
    11 [line vty 0 4]
    12 [logging synchronous]
    13 [line vty 5 15]
    14 [logging synchronous]
    15 [ntp server 128.1.20.20] NTP=Network Time Protocol
    16 [end]
    Help 3750x - any ideas ?
    2455:confused:
  2. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    I need to state more topic here -
    I'm needing to pull the "data-stream" from the reader device which is connected to the L3 switch via vlan63 IP Address (10.10.63.3 - 255.255.255.240)
    App Server w/Web services running: connected to vlan1 (128.1.70.1 - 255.255.0.0)
    I open Web service app: pulling via TCP/IP port 6700 (client)
    TCP/IP Winsock, IP Address (10.10.63.3 - 255.255.255.240) and Port# 4200 or 10.10.63.12:4200
    App Server hosting "Data Connector Service" (config file) pulls the data-stream from vlan63 10.10.63.12:4200
    I can ping the device from the server - although no data is coming through on the server:
    The telnet client can not establish a connection on (10.10.63.12:4200) as well
    I can not receive the data connected to the local L3 switch with the device pulled directly into the local switch either - although like I said - I can ping it and get 4-sent and 4-received 100%. very fast 2msec
    any one out their who may be able to shed some light on this issue ?
    Best regards,
    Bill2455:
  3. /usr/home
    /usr/home [H]ardness Supreme
    6,166
    Mar 18, 2008
    Have you tried using a laptop configured with the IP of the reader and trying with that?
  4. tangoseal
    tangoseal [H]ardness Supreme
    6,901
    Dec 18, 2010
    DO us a favor and post a real config of the switch. not some cliff note version. We need to see the real config. Also your 3750 router will pass data between subnets no problem unless you have some kind of ACL blocking xyz....
    By default a Cisco switch/router will pass EVERYTHING between VLANS. It will not block crap until you tell it to.
    Telnet will not establish a session on anything with port 4200 since telnet uses port 23.
    The switch doesnt have an "address" so to say. It will answer any SVI that is assigned an IP and the VLAN/SVI has an IP.
    For instance you can
    int vlan 1
    ip address 10.1.1.1. 255.255.255.0
    int vlan 500
    ip address 10.2.1.2 255.255.255.248
    whatever and the switch is tecnically IP'd to answer on address 10.1.1.1 and 10.2.1.2. Unless you are using a dedicated managment interface then the switch has multiple addresses.
    I would tell you run certain debug commands but without an actual config I am not sure what to tell you to run and if it is even necessary.
    see if that helps but that is all I can do for now.
    Also try and see if you can place like 2-3 ports in the same subnet and have your PC and reader device be on the same subnet and see how the traffic passes. Just eliminate intervlan routing for a minute and see if you get better results? Have you ensured there is no operating system firewall running that is blocking certain traffic?
  5. lightingguy32
    lightingguy32 n00b
    24
    Jan 3, 2010
    Have you tried running the server and the device on the same subnet?
  6. /usr/home
    6,166
    Mar 18, 2008
    You can telnet to ports other than 23....
    I telnet all the time to 25 or 80 to verify SMTP and HTTP.
  7. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Sorry here is the configuration:
    I have a Dell 2324 L2 switch. connected the reader and server on the same subnet and i can get the telnet traffic on any port it set the web service app to pull from and this set-up works great:
    When I put this same set-up on the L3 switch using this config below: I get nothing although I can ping the reader device from the server through the 3750 on the same subnet and on a different subnets so it appears its able to communicate just fine.
    version 12.2
    no service pad
    service timestamps debug datetime msec localtime show-timezone
    service timestamps log datetime msec localtime show-timezone
    service password-encryption
    hostname Switch
    boot-start-marker
    boot-end-marker
    logging buffered 16384
    no logging console
    no logging monitor
    enable secret 5 $1$GSWG$jL0KmdYxkDuwAJWts9Fbm0
    username xxxxxx password 7 0009160208540C57
    aaa new-model
    aaa authentication login default local
    aaa session-id common
    clock timezone EST -5
    clock summer-time EDT recurring
    ip routing
    no ip domain-lookup
    vlan 63
    name **reader
    no ip address
    no ip route-cache
    no ip mroute-cache
    interface GigabitEthernet1/0/1
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/7
    interface GigabitEthernet1/0/8
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10
    interface GigabitEthernet1/0/11
    interface GigabitEthernet1/0/12
    interface GigabitEthernet1/0/13
    interface GigabitEthernet1/0/14
    interface GigabitEthernet1/0/15
    interface GigabitEthernet1/0/16
    interface GigabitEthernet1/0/17
    interface GigabitEthernet1/0/18
    interface GigabitEthernet1/0/19
    interface GigabitEthernet1/0/20
    interface GigabitEthernet1/0/21
    interface GigabitEthernet1/0/22
    interface GigabitEthernet1/0/23
    interface GigabitEthernet1/0/24
    interface GigabitEthernet1/1/1
    interface GigabitEthernet1/1/2
    interface GigabitEthernet1/1/3
    interface GigabitEthernet1/1/4
    interface TenGigabitEthernet1/1/1
    interface TenGigabitEthernet1/1/2
    interface Vlan1
    interface Vlan63
    ip classless
    ip http server
    line con 0
    line vty 0 4
    logging synchronous
    line vty 5 15
    logging synchronous
    end
  8. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Yes, i did that and the app works great no problems !
  9. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    I just post the full config - thanks
  10. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Yes - i did that and it works fine, also on the Dell PowerConnect L2 switch - out of the box this works fine - I will note O/S Firewall has to be off:
    thanks in advance for any assistance you maybe able to provide!
    best regards,
    2455 :)
  11. lightingguy32
    lightingguy32 n00b
    24
    Jan 3, 2010
    I don't see a single port configured on the switch for access to vlan 1. One thing I can't remember off the top of my head with layer three switch gear from cisco is that if you don't apply a per port configuration if the port "knows" what vlan to run on with out the config. Have you tried making one of the other ports in the range gi1/0/1-5 or gi1/0/7-48 configured as such:
    interface GigabitEthernet 1/0/1
    switchport access vlan 1
    Does any one else know how a non configured switchport behaves on a 3750 that has multiple traffic passing vlans configured on it?
  12. tangoseal
    6,901
    Dec 18, 2010
    I was tired and misread .... I was thinking he was trying to telnet to his cisco switch using port 4300 or any other port other than 23. Cisco will no answer on 4300. That is what I was aiming at with my statement. Yes you are right about oher products answering on any other port.
  13. tangoseal
    6,901
    Dec 18, 2010
    There is nothing in your config I can see that is causing your issue. Something is telling me that your problem is with the device or the PC that you are trying to use.
    You do not need an IP or an interface or VLAN 1. Dont worry about that.
    Also to answer your question ...
    If a switch port is not configured on a 3750 the port is basically dead and the route processor will just ignore it for traffic reasons.
    Have you run a show interface on those two gig ports to ensure you are not getting any layer 1 CRC errors i.e. a bad cable?
    Also you are not leaving something out are you? Like you are uplinking switches rather than trunking? That will cause problems too. If you are linking your cisco switch up to the dell then you need to establish a dot1q encapsulated trunk between the two in order to pass vlan information.
    Is it possible that you can just elminate the vlan 63 and just use native vlan 1? you dont have to configure vlan 1 other than an IP for the SVI i.e.
    int vlan 1
    ip addre etc...
    then just use two non shutdown raw non configured switch ports as they are defaulted to vlan 1 when no switchport access vlan is specified.
    Also IOS has a version 15 update for that switch with a ton of bug fixes etc... you may want to look into installing the ver15 ios image. I run it on all my devices.
    But I am not seeing how the IOS version matters here.
    Have you tired different ethernet cables? COnfigure other ports and try them? maybe you have physically bad switch port. I wish I could play with your switch in person.
    Ill post my config for my 3750 for you-- which might be a little dirty as I was labbing around with last night but I havent cleaned it up as I just woke up not too long ago. It works fine for all vlans etc...
    Code:
    version 15.0
    no service pad
    service timestamps debug uptime
    no service password-encryption
    service sequence-numbers
    no service dhcp
    hostname Switch
    boot-start-marker
    boot-end-marker
    username XXXXXXXXXX privilege 15 secret 5 XXXXXXXXXX
    no aaa new-model
    clock timezone EST -5 0
    switch 1 provision ws-c3750e-24td
    ip routing
    no ip domain-lookup
    vtp domain SED.local
    I DELETED ALL THE CRYPTO STUFF
    spanning-tree mode rapid-pvst
    spanning-tree vlan 2-3,9 priority 0
    vlan 2
     name core
    vlan 3
     name Core2
    vlan 8
     name UverseTV
    vlan 9
     name Guest
    interface Port-channel1
     switchport access vlan 3
     no ip address
     no ip route-cache
     shutdown
     description Trunk-to-1921
     switchport trunk encapsulation dot1q
     switchport trunk native vlan 2
     switchport trunk allowed vlan 2,3,8,9
     switchport mode trunk
     description HP LJ 300
     switchport access vlan 2
     description Dev-Line
     description NAS-IPMI-KVM
     shutdown
     shutdown
     description BackupNAS
     description BIG-PC-GigNIC
     shutdown
     description NAS-NIC1-LACP
     channel-group 1 mode active
     description NAS-NIC2-LACP
     description TV-Mainline
     switchport access vlan 8
     speed 100
     duplex full
     description TV-Bedroom
     description TV-Office
     shutdown
     shutdown
     shutdown
     shutdown
     shutdown
     no switchport
     ip address 172.16.1.1 255.255.255.0
     shutdown
     description Trunk-to-WAP
     description Trunk-to-LivRM
    interface GigabitEthernet1/0/25
     shutdown
    interface GigabitEthernet1/0/26
     shutdown
    interface GigabitEthernet1/0/27
     shutdown
    interface GigabitEthernet1/0/28
     shutdown
    interface TenGigabitEthernet1/0/1
     description Big-PC-10gbNIC
    interface TenGigabitEthernet1/0/2
     description NAS-10GB-SR
    interface Vlan1
     no ip address
    interface Vlan2
     description Core
     ip address 10.1.1.2 255.255.255.0
     ip helper-address 10.1.1.1
     ip directed-broadcast 101
    interface Vlan3
     description Core-Sec-Brdcst-Domain
     ip address 10.2.1.2 255.255.255.0
     ip helper-address 10.2.1.1
     ip directed-broadcast 100
    interface Vlan9
     no ip address
    ip forward-protocol udp echo
    ip http server
    ip http authentication local
    ip route 0.0.0.0 0.0.0.0 10.1.1.1
    line con 0
     logging synchronous
     login local
    line vty 0 4
     login local
     length 0
    line vty 5 15
     login local
    end
    Switch#
  14. thrash408
    thrash408 Limp Gawd
    327
    Jan 22, 2010
    Try setting the ports to trunk. I know this sounds weird, but i had a phone system that acted just like what you describe. They only way to get it 100% operational is to set the access ports and phone system to trunk all traffic. Even the phone system tech was like wtf?
  15. tangoseal
    6,901
    Dec 18, 2010
    ^^ This maybe? I have seen this too and its friggin wierd.
  16. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    I have remove vlan1 and focusing on physical connection to vlan63 using ports 5 or 6 on the L3 switch;
    port 5 - connected reader device
    port6 - connected app server
    again i can ping - but still no datastream traffic ?
  17. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Yes - on valn63 physical connection to the 3750 switch; ports 5 connected to reader device and port 6 PC app server:
    I checked the cables and work on the dell switch fine, reader and PC work fine - full data stream flowing off the dell 3424 switch:
    I can ping the reader device from the PC via the L3 Switch;
    4packets-sent and 4-received O-loss - it fast too: 2msec
    although no data stream still?
  18. tangoseal
    6,901
    Dec 18, 2010
    Try and do a Clear Config and build your switch config from scratch... I have no idea why this isnt working on your switch as Cisco is literally or should be with your config passing 100% of whatever it gets to where it needs to go with no firewalling/acl'ing or any of that biz.
  19. lightingguy32
    lightingguy32 n00b
    24
    Jan 3, 2010
    Bill, could you run this command on both interfaces (gi1/0/5 and gi1/0/6) and post the outputs here?
    show interface gi1/0/5 | include input
    and the same for gi1/0/6
    this will show a number of error counters, including that of the crc error type and input error type. If these counters are high to begin with you may have a bad cable, if after you replace a cable they continue to increment at a rapid rate, then you more than likely have a bad switch port
  20. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Question: If "ip routing" is configured - TCP, UDP and Telnet session should be able to be routed via VSI and Vlan configurations for multiple vlans?
  21. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Question: in the config file: "ip routing" is enabled -
    double checking my settings ?
    2455
  22. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    in my config file - Vlan 1 and Vlan 63 - ip routing is configured
    if the reader is connected to vlan 63/port #5 and the app server is connected to Vlan 1 and to any other ports other than ports 5 and 6 on the same L3 3750x 24p-switch - should be able to receive the packets being sent routed from the reader on vlan 63 - via TCP / UDP via telnet IP#, Port# and (WinSock) Connection.
    Question - in default setting are TCP and UDP packets blocked by default - to prevent DoS attacks? If the answer is yes - what's the best method to safely enable the switch to allow TCP or UDP traffic from specific (IP and Mac) addresses and forwarded to another Vlan ?
    I've been reading about - IP helper-address
    UDP helper (09-UDP helper Configuration) http://www.h3c.com/portal/Technical_...221_1285_0.htm
    IP helper-address
    you are using this type of set-up in your own configuration :
    interface Vlan2
    description Core
    ip helper-address 10.1.1.1 ---------------- ip helper-address
    ip directed-broadcast 101 ---------------- ip directed-broadcast 101
    ip forward-protocol udp echo --------------- ip forward-protocol udp echo
    ip http server
    please advise
    2455
  23. Nicklebon
    Nicklebon Gawd
    543
    May 22, 2006
    No. If the reader is on VLAN63 then anything that needs to talk to it must either be:
    Routed or connected to a port on VLAN63.
  24. Autopia
    Autopia Limp Gawd
    246
    Feb 24, 2006
    everything defaults to vlan 1, as niclebon said you need a route for vlan 1 to speak to or access vlan 63, unless you are trunking.
  25. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Thanks for your response;
    L3 switch vlan 1 and vlan 63 configured the following:
    interface Vlan1
    interface Vlan63
    Ports 5 and 6 are configured;
    again with this type of configuration set-up: see attached config file: if "ip routing" is not enabled - if the reader is connected by Cat-6 cable to vlan 63 and the app server is connected to any other ports on the same L3 switch by Cat-6 cable - should I be able to receive data being transmitted from the reader on vlan 63 off of Port 5 or 6 - pulling data by a telnet session?
    best regards,
    2455
  26. Autopia
    Autopia Limp Gawd
    246
    Feb 24, 2006
    the reader will not be able to access the server, as for the telnet session if you are logged in as the admin you will be able to do anything just as you were connected with the console cable. IF i understand the question right, do I? looking at the setting you have HTTP setup it maybe easier for you to log in through a web browser and monitor activity via web browser.
  27. Nicklebon
    Nicklebon Gawd
    543
    May 22, 2006
    Only the devices plugged into ports 5 and 6 will be able to communicate on VLAN63.
  28. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Question:
    isn't vlan 1 addressed:
    interface Vlan1
    interface Vlan63
    and the ports 5 and 6 are addressed:
    Its able to be ping from the PC to the switch, PC to the reader which is connected to port 5 or 6 al have 4-sent 4-received 0-loss i less than 2 msec.
    So hard is all good, switchport is programed and ports are live - other wise you wouldn't be able to ping them all.
    Cables are all good -- other wise you wouldn't be able to ping the switch, PC or reader at all.
    The configuration of the switch does allow for ip routing on both VLANS
    On the switch config that I sent in prior post, Vlan 1 interface is up. Both vlans have an interface on the switch.
    There is no “upstream switch” on the config that I sent in the prior post above here. There is only 1 switch.
    Question: Since "crypto pki trustpoint" is being used here - is it possible that telnet is disabled ?
    best regrds,
    2455
  29. /usr/home
    6,166
    Mar 18, 2008
    Both of your switch ports are on the same vlan. The server and client are in different subnets are they not? If you want the switch to do the vlan routing, the switch ports needs to be in different Vlans.
  30. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    thanks for the fast reply:
    Then my question is as follows: Isn’t Vlan 1 – the default configuration for Vlan63? Shouldn’t Vlan1 connected to port #3 be able to receive or communication with ports 5 or 6?
    I can ping from the app server in any port on the L3 switch the reader device; the reader is connected on port 5 or 6; either one and gets 4-sent 4-received 0-loss?
    is this right ?
  31. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Can you give me an example please:
  32. Autopia
    Autopia Limp Gawd
    246
    Feb 24, 2006
    NO, when you put the command switchport access 63 you told ports 5 and 6 only vlan 63 is able to access these ports. do command show vlan that will tell you everything.
  33. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    So although I can ping from the app server which connected on any port of the L3 switch, ping the reader device successfully;
    although I'm not able to receive anything from the reader back to the server? am i understanding this correctly?
    2455
  34. Autopia
    Autopia Limp Gawd
    246
    Feb 24, 2006
    From the switch you will be able to ping the devices, if you are at the server and trying to ping the computer that is connected to vlan 63 you will not be able to, UNLESS you add a route for that vlan. or move the server to the same vlan.
    from command line.
    config t
    int fa0/8 if that is the port the server is connected to
    no shut
    exit
    go to server and ping computer they will be successful.
  35. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Yes and successfully
    Although thinking about this a little here - I have not tested the reverse of this test:
    pinging the server from ports 5 or 6: would that matter?
    2455
  36. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    I can ping from the server that is connected to port#3 on the L3 switch
    I'm pinging 10.10.63.2 connected to port-5 The response is as follows:
    4-sent 4-received and 0-loss very last 2msec
    any thoughts?
    2455
  37. Autopia
    Autopia Limp Gawd
    246
    Feb 24, 2006
    i don't understand the question, could you please elaborate, what do you mean from ports?
  38. Autopia
    Autopia Limp Gawd
    246
    Feb 24, 2006
    if you are in telnet session or console cable to the switch you will be able to ping any device connected to it. again if you go to the server and try to ping the computer you will not be able to, or if you are at the computer and ping the server you will not be able to, you will be able to ping the switch from either device. again once you moved ports 5 and 6 to vlan 63 you removed vlan 1, kind of like making it invisible to vlan 1. if you move the server to vlan 63 it becomes visible to all the devices connected to vlan 63...
  39. bill2455
    bill2455 [H]Lite
    66
    Jul 3, 2013
    Vlan 63 is config to ports 5 and 6 in my configuration file: see below
    interface Vlan1
    interface Vlan63
    interface GigabitEthernet1/0/5 (Port 5)
    interface GigabitEthernet1/0/6 (Port 5)
    interface Vlan1
    interface Vlan63
    ip classless
    ip http server
    line con 0
    line vty 0 4
    logging synchronous
    line vty 5 15
    logging synchronous
    end
    is this helping ?
  40. Autopia
    Autopia Limp Gawd
    246
    Feb 24, 2006
    are you in a telnet session to the switch?
