3635 BRICK
napster0317
Came home from work, and found my Ipaq 3635 was a brick! I need it to keep me on sched. Any one know how to debrick this. it is stuck at the Ipaq screen you get when you reset it. cant seem to get it to sync HELP!!!!
Only advice i have is hold the reset down for 5 seconds and restore it to factory settings, you will loose everything though.
LOVE YOUR CHOICE IN CARS, had one myself, also I have tried reset for about 30 minutes it seems that the rom image was fubar.
youll have to check out some IPAQ forums and see what they tell you.
