I used the rice sized drop of paste when mounting, but I had t take the block off and noticed even that much spread all the way to the edges. So, I remounted using abut 70% of a rice sized. Is it possible I didn't get correct coverage from the center of the CPU heat spread out?I'm assuming that if it didn't spread all the way to the edges, it was within 3mm. Are teh chips near the center or spread out on the Zen 2?
TIA
TIA
