3600 mhz cl18 or 3200 mhz cl16 ddr4? for Ryzen 3600 build
biggles
I am leaning toward the following Ryzen upgrade system:
Ryzen 3600
Asus Prime x570-p motherboard
Then keep rest of components of current system (Corsair H60, gtx 1070, etc).
After some research it appears that (2x8 GB 3200 mhz cl16) or (2x8 GB 3600 mhz cl18) ddr4 kits are popular choices in order to balance price and performance. Price is about the same for either. Despite the latency advantage of the 3200 mhz cl16 ddr4, it appears 3600 mhz cl18 ram is slightly faster.
The Asus motherboard does not officially support anything above 3200 mhz. But it seems plenty of folks can achieve this on other boards.
MAG0N3X
I personally dont see any reason. if the bus bandwidth is limited to 3200, your 3600 will not work at all.
motherboard will only squeaking and not work at all. or if it works, then only at the bus frequency ... 4sure
MAG0N3X
i check some more nfo bout it here
and I think that exposing the chip timings to a smaller bus you will even lose in performance than if you took it directly under the bus
mda
3600 CL16 is no longer expensive.
If your board/CPU won't run 3600 CL16 it will probably do 3200 CL14 no problem.
EDIT: Yes my vote is for 3600 CL16
ThreeDee
either way ... you'll be happy.
I run some Hynix chipped Hyper X Predators 2 x 16GB 3200mhz CAS 16 stuff at 3800mhz CAS 18 with fclk 1900 (1:1) ...
atp1916
[H]ard|DCoTM x1
Love the Samsung CL14 bdie 3200 stuff. Easy 3600@CL14 with a little bump on the ram voltage. Could do higher, but this 3950s IMC is a bit flaky over 1866 1:1, so it's fine.
3600@CL16 is definitely not a bad route though, especially if the price is there.
