LFaWolf
- Aug 7, 2016
I have not kept up with monitors development so point me in the right direction.
Main use for productivity (programming) for multiple PC plus a gaming PC so I need to switch inputs from time to time. Which one would you choose?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824025363
I can get this new for $650.
Pros: 5 inputs that can all do 60Hz. Smaller base. Longest warranty of 1-year.
Cons: Not really a con but I don't have AMD GPUs for Freesync (limited to 60Hz anyway). Not curve.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824025211
I can get this used for $420.
Pros: cheapest.
Cons: Only Displayport can do 60Hz. HDMI limited to 30Hz. I will need to unplug cable to switch input for 60Hz. No warranty. Not curve.
http://www.newegg.com/Product/Product.aspx?Item=0JC-0007-00D81
I can get this refurbished for $655
Pros: Curve, 3 inputs.
Cons: Not IPS (VA panel). 90-days warranty. Only Displayport can do 60Hz. HDMI limited to 50Hz but I think that could work for me.
The only concern I have is the warranty for any of them. Should I wait for better deal? I am not in a hurry as I run 3x surround but for programming it would be nice to have one long monitor for Visual Studio code.
Pros: cheapest.
