In France they have 20% sales tax. So a street price of 650 translates to a base price of ~540
Is anyone else having sleep issues with this monitor? I have my screen set to shutoff after 10 minutes of inactivity. Screen goes black, says no input, turns off, then comes back on saying no signal and repeats the process. https://www.youtube.com/watch?v=FJv5luSOE-Q
Yes I had similar issues. Going into the BIOS and disabling the internal GPU solved it for me. I guess that since Displayport is plug-and-play, as soon as your display goes to sleep the motherboard thinks it's not connected anymore and switches to the internal GPU
It still pulled some wacky shit on me when I disabled the iGPU (in my BIOS called IGD - Asus Maximus VI Hero). I booted up and the second screen (the one over HDMI) was still without input. Loading up GPU Tweak after manually turning the monitor on in the Windows Display control panel resulted in the same dropping of the monitor input signal (again the HDMI one).
No dice on that front. Primary adapter was already PCI-E. I disabled IGPU multi monitor and render standby. Same issue.
Unless you are planning to buy TWO cards for SLI then dont worry about it. You will be reducing settings especially AA long before 4 GB becomes an issue.Anyone know if waiting for the gt 970 8 GB would be better than going with the 4 GB since the resolution is higher and games are either more demanding or not optimized well aka watch dogs?
Was looking to pick one of these up and I'm surprised that these are still sold out everywhere (at regular price).
Yeah, still very popular. NCIX still has a 300 dollar mark up here in Canada land. But now that the curved display is going to be available I hope the flat one will drop to a decent price point.
These monitors are just too much awesome for not everyone to be sporting one so game companies all support the 21:9 resolution natively..
I finally opened mine and I have to say I'm missing the vertical space a little bit. The monitor is certainly wide but it comes with the tradeoff of being "short" and so far I'm undecided as to which display provides more immersion...this or my 32" BenQ that looks huge sitting next to it because it's so much taller.
Very pleased with the panel itself, though. I don't know if the previous complaints were overblown or if the ones that shipped from Massdrop did receive better quality control, but it's very pleasing to look at and mine has no backlight bleed to speak of. There is a minor amount of IPS glow, but nothing like the "corners are on fire" effect that I expected after looking at some of the pictures that were posted. It's not distracting during games, even in the dark, and I don't see it during normal desktop use. The blacks aren't as black as my BenQ of course, but they're not as bad as I expected either. This is a really, really nice panel.
One minor nitpick though is that I'm having the same problem that murdoc described here with the monitor coming back on on its own after Windows puts it to sleep and displaying "No signal" over and over. For now I just disabled the Windows sleep setting and have been turning the monitor on and off manually, which isn't a big deal, but it would be nice if the sleep worked properly in the event that I forget to turn it off. I need to go into my BIOS and make sure that my i7's GPU is disabled and will report back.
Yes, mine does something similar, although usually not right after it initially turns off, but sometimes much later. I've had the monitor go to low-power mode then seen it wake up after going to bed. It's annoying as hell. Never had this happen with a previous monitor.
If I put the COMPUTER to sleep, the monitor turns off and stays off. The issue is lets say I leave my computer on and walk away. After 10 minutes my monitor is set to shutoff from the power settings in Windows control panel. This results in the endless on-off-on cycle. I didn't change anything system-wise when I got this monitor. My QNIX 27" was hooked up via DualLink DVI and that worked just fine. My 37" Vizio LCD connected via HDMI would display no signal (can't power down since it's a tv). It's got to be something with this monitor or the DisplayPort behavior. I may test an HDMI connection tonight to my computer and remove the DisplayPort cable and port completely from this equation and see what happens.
That's exactly what happens to me, and it happens with both my Win7 laptop and my Win8.1 desktop (I have each connected via DisplayPort via a real KVM switch). I have to turn the monitor fully off to be sure it won't turn on for no reason after Windows tells it to power down.If I put the COMPUTER to sleep, the monitor turns off and stays off. The issue is lets say I leave my computer on and walk away. After 10 minutes my monitor is set to shutoff from the power settings in Windows control panel. This results in the endless on-off-on cycle. I didn't change anything system-wise when I got this monitor. My QNIX 27" was hooked up via DualLink DVI and that worked just fine. My 37" Vizio LCD connected via HDMI would display no signal (can't power down since it's a tv). It's got to be something with this monitor or the DisplayPort behavior. I may test an HDMI connection tonight to my computer and remove the DisplayPort cable and port completely from this equation and see what happens.
It doesn't matter who doesn't have this issue (or who does have it but doesn't realize it). It's an issue for at least some of us...
I'm going to try enabling DP 1.2. (Edit: Well that was a short experiment. DP 1.2 didn't work with Win7 at all, and within seconds, I noticed screen corruption under Win8.1.)
I get the same endless display on-off cycle when Windows tells the monitor to enter power saving mode. This requires me to manually power off the monitor.If I put the COMPUTER to sleep, the monitor turns off and stays off. The issue is lets say I leave my computer on and walk away. After 10 minutes my monitor is set to shutoff from the power settings in Windows control panel. This results in the endless on-off-on cycle. I didn't change anything system-wise when I got this monitor. My QNIX 27" was hooked up via DualLink DVI and that worked just fine. My 37" Vizio LCD connected via HDMI would display no signal (can't power down since it's a tv). It's got to be something with this monitor or the DisplayPort behavior. I may test an HDMI connection tonight to my computer and remove the DisplayPort cable and port completely from this equation and see what happens.
Yep, that's exactly what I'm seeing on mine too.Is anyone else having sleep issues with this monitor? I have my screen set to shutoff after 10 minutes of inactivity. Screen goes black, says no input, turns off, then comes back on saying no signal and repeats the process. https://www.youtube.com/watch?v=FJv5luSOE-Q
Two NVIDIA Titans, latest WHQL drivers (344.11).That is weird, which video card are you using? I have been using DP 1.2 since I received the monitor back in May without problems.
Video card is an Asus Strix GTX 780 6GB w/ latest certified drivers on Windows 8.1 64-bit. Monitor itself has a late 2013 built date according to the EDID data. Different DP cables and switching between DP 1.1/1.2 seems to make no difference.
Other monitors on the same system do not have this issue. The LG monitor seems to work as expected on my HP laptop's Intel video for some reason.
I know I wasn't the one being asked, but I have an Intel Core i7 3970X. I don't think it has any sort of native graphics support.
Nope. GPU-less Intel Xeon E3-1230v3.Do you have a processor with integrated GFX?
So...if u had to buy one which one would u get? The LG or the benq? I play ONLY games.
https://www.youtube.com/watch?v=CcaktV1iiGk
Video review for LinusTechTips already confirms it doesn't fix backlight bleed, at least for the review panel he was given. He liked everything else about it, but keep in mind he rarely says anything truly bad about products he features, which is why I unsubbed a long time ago. Watch his "reviews" more like you would a commercial, not for a truly informative review that tells you the real pros and cons of a product.
The guy is a great speaker though, I'll give him that...
Looks like we'll have a VA option sometime next year:
https://pcmonitors.info/samsung/samsung-s34e790c-curved-ultrawide-va-monitor/
