32GB Kit DDR4 DEALS $93-$100 (Amazon Prime & Newegg)
Nside
RAM is dropping a bit in price again, though most are late to the party.
Here's some deals I spotted:
G.Skill Aegis 3200MHz CL16-18-18-38 .... 32GB (16x2)
NewEgg, $97 Now $103... Free Shipping
TEAMGROUP T-Force Dark Za 3200MHz 16-18-18-38 .... 32GB (16x2)
Amazon Prime, $100... Free Prime Shipping
Several other colors are the same price as well.
Red Vulcan Z with same specs are $93 @ Amazon (Prime)
Or $92 @ Newegg (Free Shipping)
Edit, added NE link for Vulcan RAM
QSnexus
The prices went up by about $9 on the same Teamgroup modules for those two Amazon links that were posted originally.
edit: The prices are higher on them unless you are signed in with a Prime account to see the lower prices. May need to edit the title to say Amazon Prime instead of Amazon.
ir0nw0lf
Just a small FYI on that G.SKILL $97 kit: no metal heat spreaders, just some printed sticker thingy. Probably not a huge deal to some.
Nside
Yep. I've used Aegis in lowish-profile builds though, good stuff in my experience.
Most of the time (I mean 99.99% of the time) a heat spreader is completely unnecessary unless you plan on ramming more than the stated 1.35V through it. Otherwise, it stays well within spec, and heat spreaders are aesthetic only.
Unless we're talking about good ole RDRAM from 20 years ago... that stuff needed all the heat-spreader you could give it, and basically started the nonsensical trend of "Bigger The Heat Spreader = Faster The RAM"
TheGeekFreek
Ive got 64Gb (4x16GB) of the Aegis stuff in my Dell G5/Gaming desktop and it works fine.
Never needed big fancy heatspreaders at stock speeds/voltage.
Reactions: Nside
DJS4000
seeing this thread made me check prices over here. i bought 32gigs of 3.200mhz corsair vengeance for 107€ shipped, so thanks for that :)
Reactions: Nside
Nside
Good buys but someone tell me why I need more than 16 gig for gaming. I
You don't currently.
But RAM prices fluctuate, and requirements continually increase.
Also, with 32GB, you might be able to open a couple of chrome tabs while gaming too... lol
sfsuphysics
I don't get it
You don't, at least now, so if buying a new rig get the 16G (2x8) set of this for half the price, and if more ram does help in the future then you can buy another 16G set. But not worth "future proofing" because chances are by the time many (any) games really utilize 32GB ram, you may be moving onto the next type of ram.
TheSlySyl
I was hitting the cap of my 32GB with multitasking and RAMcache for improved loading times/less SSD stress.
I'm actually gonna go up to 64GB with this because.... i can?
(And that'll give me 16GB for a dedicated plex server)
Ranulfo
When memory is cheap (yay ram cartels), buy as much as you can and might need in the future. With systems lasting people 4-5 years at least these days, it doesn't hurt. While I absolutely didn't need 16GB ddr3 ram in 2011/12, those two systems I bought it for never had a lack of ram problem and still don't. I also didn't have to worry about finding matching stuff down the road. Though that usually isn't a big deal these days.
/dev/null
So if you can live with DDR4-2666 (and with 8 ranks, that may be all the speed you can pull out of a memory controller anyhow), you can have 128G ram for $360..
Link
SvenBent
Maybe not for gaming. Bu there are other things than gaming a computer can be used for. Some of my tasks I can utilize up to 240gb (if i had it ) of ram for major speedups
SPARTAN VI
Something like a modded Skyrim/Fallout with 4K/8K texture packs might push DRAM capacity. Personally the only time I've seen a game gobble up DRAM was MS Flight Sim 2020. When I was on 16GB of DDR4 I saw FS2020 ate it all up, and now on 32GB it still eats it all. This is obviously the exception, not the rule. 16GB will be more than enough for the foreseeable future.
