TechieSooner
- Nov 7, 2007
Alright. Let's go along with this for a bit.Well this has happened to me, before I turned off UAC and whatever (I think there's another thing you can turn off too, but it's been off for a while now so I forget), I got three yes/no dialog boxes to do a simple windows explorer task. Usually it was one or two but this time I got three.
Put the facts where your mouth is.
Please detail how I can get three UAC prompts after doing a single action.
If you do anything other than post these steps, you're nothing more than a FUD-spreading troll. Back up your nonsense claims.
Again, I'll go along with this once more.Well, a lot of the time it is. You've probably never tried it. It may not be easier, but most of the time they have more features and therefore, to me, are better.
Name for me what's better about Microsoft's third party search for XP versus Vista's built in search.
No, I read it loud and clear. Your quote was this:Ok, not even gonna respond to this, you obviously haven't read my entire posts (or just don't understand them).
Superfetch does it BASED ON ACTIVITY. It's not just guessing.I do not want my system to automatically load things into my memory that it thinks I might use.
If you cannot understand this, let me reword the whole Superfetch thing for you.
Would you rather have RAM sitting around doing NOTHING, or RAM pro actively speeding apps up?
Either way, it's being consumed. It's using electricity. It's producing heat. It's slowly dying. Why not put it to use?
Just yours, troll.Sure, if you misquote anybody I'm sure their credibility could be lost.
You flat out said you've never tested Superfetch, but yet you continue to argue about how it works.
I haven't seen this much Vista FUD since its release.
