Hi guys,
I would like to ask the local gurus about a 32+ inch monitor which will be used for a workload of photo retouching and manipulations as well as games. It will be sufficient that the display covers the entire sRGB color space without going into wide-gamut territory and should have a good gamma curve for 6500K. Also the dimming must be DC and not PWM.
I know that this would be kind of a multipurpose display, but I am not a competitive gamer, just gaming for pleasure. So the obvious choice would be an IPS UHD display with decent response time and input lag.
I should clarify that my plans don`t include ulra-wide and I want 16:9 panel.
Can you give some recommendations for particular models? The budget is a bit flexible and I want quality stuff.
Thanks!
Thanks!
