32" High Definition LCD TV - Olevia LT32HV LCD -for $600, good?
jhego
A local seller is selling this model for 600$. Is it a good price for the specs and quality?
Liquid Crystal Display Technology Is The Future Of Television! The Syntax Olevia Is So Breathtakingly Sharp, It's Real!
One of the newest Olevia models, the LT32HV is a HDTV-ready 32-inch LCD TV, featuring Super-IPS (Super-In-Plane-Switching) technology to provide sharp, vivid digital entertainment images from analog and digital TV signals, DVDs, VHS and video games. The high-end benefits of Super-IPS provide the best display performance with high color saturation, the widest viewing angles, sharpest images, best response times and the minimum amount of color shift and distortion from any angle.
Highlights of the LT32HV include 178 degree expanded viewing angles that give excellent picture quality from any room location, exceptional 1200:1 dynamic contrast ratio, high resolution of 1366 x 768 (WXGA), 8ms response times to display rapidly-moving images with smooth transitions that eliminate ghosting effects, 800 cd/m2 high brightness, and a 16:9 cinema-style widescreen aspect ratio with automatic progressive scan. Dual built-in NTSC TV tuners display split screens and Picture-in-Picture. The LT32HV also features the newly-designed, stunningly-attractive black and charcoal bezel to frame the space-efficient LCD TV that can be wall mounted using an optional VESA-standard mounting kit. Furthermore, the LT32HV features a patent pending rear panel AV Lamp for best visibility when accessing the rear inputs.
Features:
32" 16:9 Cinema-Style Widescreen Aspect Ratio
HDTV Display Ready (480i, 480p, 720p, 1080i)
1200:1 High Contrast Ratio
Wide XGA 1366 x 768 Resolution
High Brightness 800 cd/m2
8ms Response Time
Dual Built-in TV Tuner
PIP & Picture Grid Views
Digital YC 3D Comb Filter
HDTV, Progressive Scan Input
178 / 178 Degree Wide Viewing Angles
VGA (DB15) & DVI-I/HDCP
15W + 15W Surround Speakers
Specifications:
Screen Size: 32" TFT LCD
Aspect Ratio: 16:9
Brightness: 800 cd/m2
Contrast Ratio: 1200:1
Pixel Resolution: (H x V) 1366 x 768
Response Time: 8 ms
Viewing Angle: 178 (H) / 178 (V)
Cabinet Color: Black
Video:
Digital 3D Comb Filter
Progressive Scan
2:2 / 3:2 Pull Down
Digital Picture Noise Reduction
Resolution Scan: VGA, SVGA, XGA, SXGA, WXGA
De-Interlace
Adjustable Color Temperature
VGA Auto Frequency Correction
TV Auto Frequency Tuning
Audio:
Surround
Mute
Audio Output: R/L RCA preout and Sub-Woofer preout
Earphone Output: Mini - Stereo Jack x 1
Speaker: 15w x 2
Auto Sound Level Control
Auto Voice Correction
Input / Output:
HDTV Component Input Y, Pb/Cb, Pr/Cr x 2 (480i, 480p,720p, 1080i)
Composite Video Input RCA x 2
S-Video Input 4-pin DIN x 3
Audio Input RCA L/R x 6
DVI-Input: DVI - I x 1
VGA Input: DB15 x 1
TV System Support: NTSC
TV Tuner Input: TV / CATV RF x 1, NTSC Only
Service Port: RS232 x 1
Function:
TV / Video Switch
Dual Tuner*
Channel Return
MTS
PIP / Split Screen / Grid
Viewing Aspect Ratio 16:9, 4:3, Zoom
Clock / Alarm
Sleep Timer
Favorite Channel Setting
V-Chip Parental Control
Close Caption
Language: English, French, German, Italian, Spanish, Portuguese, Swedish, Simplified Chinese and Traditional Chinese
Other:
Wall Mounted Type VESA 200, WM-15D / WM-20D
Horizontal Frequency: 30 - 80 KHz
Vertical Frequency: 50 - 80 KHz
PC Frequency Support: 1366 x 768 @ 60 Hz (Max)
Tuner Box: Removable for ATSC Replacement
Power Consumption AC: 180 Watts (Max) ?
Dimensions:?
39.8" (W) x 22" (H) x 11.1" (D) with Stand
39.8" (W) x 19" (H) x 4.6" (D) without Stand
Weight:
55 lbs with Stand
45 lbs without Stand
Safety Certification: CE, FCC, UL, CUL, CB, TUV
Energy Star
brighton
i have a 32" Olevia (6 months old) its great only complaint i have is no HDMI input but i knew that before buying it.
