haste
- Sep 27, 2005
http://www.wesellbatteries.com/product-p/aarechargeable_8pack.htm
$39 shipped!
enjoy...just got my order!
$39 shipped!
BTW, is this "the Fappening" that I hear everyone talking about?
That's what he said.
Any issues using them that you've seen? I'm wondering if the 1.2V (vs 1.5V of a normal AA) trips up any of your electronics.
If you're worried about it you can try something like this:
Stay away from these non-precharged technology batteries.
What he means is that these are a different tech than eneloops. With eneloops, you charge them, throw em in a device, and even if you don't charge them for a year unused you should still have about 90% of its original capacity.Thank you for that very informative post.
Edit: SHITASSFUUUPISS... I just realized I parroted the post above mine. *facepalm*
All kidding aside, buyers should note that these are standard NiMH cells - NOT Low Self Discharge (like Eneloops).
So these are great for situations where you're going to charge them and then use them immediately in a high drain device.
If you want something that you can charge and leave sitting on a shelf or in a drawer for a long time, or something that you can put in a low drain device (a clock, remote control, etc), you'll be better off looking for LSD NiMH cells.
These are the really old school type batteries, which means they hold 2450mah on day one, but if you don't use it for two weeks, you may already be at 1000mah capacity left. Don't use it for a couple months, and they are completely dead.
So for high drain devices where you are sure to need to recharge them very regularly anyway, like on say RC vehicles, these are great. But for most other low drain devices like mice and headphones and crap like that, you really want low discharge precharged batteries.
Would these be good for Xbox One controllers? Only have two controllers being used, but practically 5+ hours every day. Don't have enough other devices to use the rest, so most would sit until the ones being used are completely dead (no longer rechargeable), then swap in others from the rest.
Got a recommended charger for these?
Thank you for those very informative posts.
Duracell does make good rechargeables, but I agree with the gents above. Eneloop is superior.
I think I'd sooner recommend you just get a dock. Then you don't have to worry about swapping batteries and keeping your spares fully charged.
I've got one of these, no issues as of yet: http://www.amazon.com/Nyko-Charge-B...&qid=1410017995&sr=8-1&keywords=xbox+one+dock
Thanks! I can use these with my fleshlight...
Get the precharged type of batteries for that. Unless your flashlight is on all the time, you'll have to recharge the batteries every few months. The low discharge (precharged) batteries hold something like 75% of their charge over a year (read NLEE reviews, cause I'm doing this from memory and memory has some bad cells).
It's not on all the time, but I do use it two or three times per day. So you are saying the precharged batteries are best for that kind of use? I'd hate to be in the middle of an important task and have the batteries die on me.
Aren't AA supposed to be 1.5v ?
typically they are yes. Thats weird that these are 1.2v.
not rechargeable ones, those are 1.2v... most that i've seen...
when charged to the max some of them go up to 1.34v
