phinix
- Dec 13, 2005
Looks like we have another 32" 1440p monitor, this time from AOC, model Q3277PQU.
Couldn't find a thread about it, so opened one.
I wonder if this one uses same panel as BenQ and suffer from banding issue etc
Aria has it for £351.88 inc. VAT - great price.
Display
:: HD type: Wide Quad HD
:: Display: LED
:: Display technology: A-MVA
:: Display diagonal (metric): 81.28 cm
:: Contrast ratio (dynamic): 80000000:1
:: Viewing angle, horizontal: 178°
:: Viewing angle, vertical: 178°
:: Display number of colours: 1070M
:: Pixel pitch: 0.276 x 0.276 mm
:: Aspect ratio: 16:9
:: HDCP: Yes
:: 3D compatibility: No
:: Supported graphics resolution:s 2560 x 1440
:: Display resolution: 2560 x 1440 pixels
:: Display brightness: 300 cd/m²
:: Response time: 4 ms
:: Display diagonal: 81.28 cm (32")
:: Contrast ratio (typical): 3000:1
Ports & interfaces
:: DVI port: Yes
:: VGA (D-Sub) ports quantity: 1
:: HDMI ports quantity: 1
:: USB 3.0 ports quantity: 1
:: USB 2.0 ports quantity: 4
:: DisplayPorts quantity: 1
Multimedia
:: Built-in speaker(s): Yes
Design
:: Colour of product: Black, Silver
Audio
Performance
:: -in speaker(s): Yes
Ergonomics
:: Tilt adjustment: Yes
:: Tilt angle: -5 - 24°
:: Height adjustment: 18 cm
:: Pivot: Yes :: Height adjustment: Yes
Power
:: AC input voltage: 100-240V
:: AC input frequency: 50/60 Hz
:: Power consumption (standby): 0.5W
:: Power consumption (typical): 60W
Weight & dimensions
:: Width (with stand): 74.188 cm
:: Depth (with stand): 17.12 cm
:: Height (with stand): 65.9 cm
Display
:: Display: LED
:: HDCP: Yes
Ports & interfaces
:: DVI port: Yes
Multimedia
Design
Audio
Performance
Ergonomics
Power
Weight & dimensions
