This is the only OLED I have seen in person, and maybe I had high expectations but I couldn't believe how washed out and purple the screen looked. Maybe it was the store lighting at Best Buy, but it looked absolutely horrid next to the beautiful IPS displays next to it. Are OLED's intended for use in only dark controlled rooms, or was something not set up properly with this monitor?I suggest you go to Rtings and do your research depending on budget. Most 32" are 4k
the best = Dell Alienware AW3225QF
Yes, you viewed it on the bridge of the Abramsprise. Your office will never be that bright.This is the only OLED I have seen in person, and maybe I had high expectations but I couldn't believe how washed out and purple the screen looked. Maybe it was the store lighting at Best Buy, but it looked absolutely horrid next to the beautiful IPS displays next to it. Are OLED's intended for use in only dark controlled rooms, or was something not set up properly with this monitor?
Sounds like way too much light and it makes sense for in-store lighting. In this best case scenario for IPS screen you might get false impression they are somehow better but this is not relevant presentation for normal usage back at home.This is the only OLED I have seen in person, and maybe I had high expectations but I couldn't believe how washed out and purple the screen looked. Maybe it was the store lighting at Best Buy, but it looked absolutely horrid next to the beautiful IPS displays next to it. Are OLED's intended for use in only dark controlled rooms, or was something not set up properly with this monitor?
I'm glad someone is finally saying it. Also - the "triode" pixel layout looks like ye olde shadow mask CRT. Not necessarily a bad thing when your pixel density is high enough. But yeah. this whole "light controlled room" thing has been around for a long time and unfortunately it's what you have to do when you want the best (emissive pixels) image quality.Sounds like way too much light and it makes sense for in-store lighting. In this best case scenario for IPS screen you might get false impression they are somehow better but this is not relevant presentation for normal usage back at home.
I have my 3rd gen QD-OLED in front of ceiling lights and at full blast black level is visibly rised but its still lower black level than I have on gaming IPS at lowest brightness at 80-90 nits. I use that IPS at 200-250 nits usually and and lots of light in the room helps hide black level being bad. QD-OLED has much better black level in this worst lighting situation (unless I open window curtains with window on the other wall I need not do that when playing games )
In other words it might not be perfect but totally non-issue in my case and I didn't optimize lighting in the room in any way for current monitor setup.
BTW. This effect QD-OLED has is similar to what users have or still have to deal with CRTs and plasmas. It isn't such a big issue and especially since QD-OLED screen in this regard is much better than even the best CRTs or plasmas and we not always had best CRTs/plasmas we still used them with some light in the room. Generally not will full ceiling lights and for darker games where glowing black level would be an issue all that needs to be done is either turn lights off or tone them down. Maybe use different lamp, eg. relatively dimmer lamp placed somewhere where it won't cause black level to rise e.g. behind monitor.
I would only advice against QD-OLED if you know for a fact you will always have tons of light in the room because then there might be better options like WOLED or even FALD LCDs
When you do already sit in dark room (or wanted to but had to use ambient light for LCDs...) then QD-OLED will have amazing image quality.
This is a common issue with QD-OLED panels due to the lack of a polarizer. The higher the luminance of ambient light, the more it activates the quantum dot layer. The purplish tint isn't as much an issue in normal room lighting, but perceived black level can still appear elevated. WOLED panels don't have this issue.This is the only OLED I have seen in person, and maybe I had high expectations but I couldn't believe how washed out and purple the screen looked. Maybe it was the store lighting at Best Buy, but it looked absolutely horrid next to the beautiful IPS displays next to it. Are OLED's intended for use in only dark controlled rooms, or was something not set up properly with this monitor?
