NukeDukem
- Feb 15, 2011
Nice to see it's finally available in Canada. I'm a stone's throw from the Ontario border; for a while there I thought I might have to start smuggling them in for you guys
Has anyone tried overclocking this display past 165hz, is that even possible? If push button OCing gets you from 144->165, would 180+ be feasible with some fine tuning?
Also, anyone have DP cable problems? The 6ft cable that came with the monitor works fine, but the 16ft cable I got off amazon only works with one of the 3 DP ports on my card, the other two give constant black frames/cutting out.
DP cables differ. You need a quality one for 165hz and especially if it's longer. (I don't have anything to recommend)
Looks fairly good compared to mine. But do you see it in normal usage (daylight conditions, room light on)? Mine was just inky black that way.Hi there,
I recently bought the LG32GK850G. It's an amazing monitor which I (plan to) use as a daily driver and for gaming. The first one I got had 3 defective pixels so I returned the monitor. The second and current one seems to be perfect, except for some glow in the lower left and the upper right corners (see picture). It's definitely different from the image in the review on Tft central. I set the brightness to 20 in order to compare it to the review. For normal use I set brightness at 30/40 and the glow is probably more visible.
To be fair, due to the large size of the monitor there is a minor shift in color anyway. Besides, during day-to-day usage and gaming it's not a real problem and definitely not as bad as the glow on some IPS screens I tried before.
Should I worry about it at all? Realistically, what's the chance of getting one that has no glow at all (besides the possibility of getting bad pixels, scanlines and/or other problems)?
Thanks in advance!
PS: photo is taken with my iphone. With my DSLR the glow was even more visible, but I was not sure about the settings (shutterspeed) for a realistic image of the problem.
But really watch for those vertical lines in bright graphic games. I had to send mine back but I noticed them too late, so I lost 20% of my money.
That is almost as good as it gets. If you don't have dead pixels, vertical banding, color tint changes on white or other issues that screen is a keeper. There is a very slight chance to get one that's even better but a much greater chance to get one which is much worse so I wouldn't gamble Ultimately the only person that can really decide is you.Should I worry about it at all? Realistically, what's the chance of getting one that has no glow at all (besides the possibility of getting bad pixels, scanlines and/or other problems)?
HPM said:Thanks for the reply.
PS: what is the best way to use g-sync? what settings are important in the nvidia control panel and what settings do I need to adjust in-game? V-sync on/off?
I'm very happy owner too. It is not perfect monitor with some known VA panel issues. Also it is pushing my gtx1070 to the limits... (time to upgrade next year LOL) I'm glad you like yours.
I'm not gsync expert, but in general I have Vsync on via nvidia panel, then in game I have vsync on as well if I remember correctly. I'm new to gsync too, so I'm still learning.
There is a good read by blur busters I recommend reading.
BTW: I got i1 Display Pro and after quick calibration was RGB set to 48/42/49 with brightness/contrast 22/70 and gamma 3.
The quick check gave me:
Device: 32GK850G @ 0, 0, 2560x1440
Instrument: i1 DisplayPro, ColorMunki Display — LCD (generic)
Correction: None
Display profile: 32GK850G #1 2018-05-23 22-51 2.2 F-S XYZLUT+MTX
Display profile luminance: 117.7 cd/m²
Display profile whitepoint: xy 0.3129 0.3284 (XYZ 95.25 100 109.21), CCT 6500K
Measured luminance: 118.9 cd/m²
Measured whitepoint: xy 0.3128 0.329 (XYZ 95.07 100 108.88), CCT 6499K
Assumed target whitepoint: 6500K daylight, xy 0.3128 0.3292 (XYZ 95.02 100 108.77)
Measured black luminance: 0.0498 cd/m²
Contrast: 2388.7:1
Testchart: verify.ti1
Simulation profile: None
Gamma mapping: N/A
Whitepoint simulation: N/A
Chromatic adaption: Bradford
Devicelink profile: None
Evaluation criteria: RGB
Date: 2018-05-23 23:18:19
You might initially be confused by this: why is Vsync “On” by default for all games in the NVIDIA Control Panel, even though we told you to turn it off in your games?
The Vsync option in the NVIDIA Control Panel is a special type of G-Sync-aware VSync, which only kicks in at high framerates. NVIDIA has optimized this to work well with G-Sync. The Vsync option in your games is the more traditional type, which is best left off.
In short, the rule is: Leave VSync enabled in the NVIDIA Control Panel, but disable it from within games. Only disable it for an individual games in the NVIDIA Control Panel if you really need to reduce input latency as much as possible.
Turn off global vsync from nvidia CP. turn on gsync if you have it avaliable, if not, its ok.
Install MSI afterburner, open rivatuner, and on the right side, type in the number of your monitor refresh-rate in the field "frame-limit".
This should fix things. If you have gsync, type in 1 number below your monitor refresh-rate, in that field.
Here's my review of this monitor.
I assume you would not recommend this monitor. ;^) I'm considering it or the Acer. https://hardforum.com/threads/acer-predator-z1-z321qu-or-lg-32gk850g.1962060/ The LG gets a bunch of good reviews. I guess you got the lemon of the lot.
This piece of fucking crap, randomly flickers on and off, it can't even hold a god damn signal, what a fuck OH G, OH you son of a bitch! I give up with these fuckers. I'm so fucking sick of this cheap dog shit man. REEEEEEE!!!
Wow, ok . Check the cable before you blow a gasket.
Had the same issue with amazon.ca's "CableCreation 16.5 Feet DisplayPort to DisplayPort Cable", it flickered to black every other second using the top two display ports on my 1080Ti. Ran pretty good on the bottom DP but still got the odd flicker every few hours.
Ordered the "Rankie DisplayPort to DisplayPort Cable, 15 Feet, Black" and that's been working perfectly since last Friday.
That guy aboves issue is exactly what happened with mine when paired with a shitty DP cable.
I used the one that came with the monitor. You're telling me that LG is shipping these monitors with cables that don't work?
Anyone else having the menu pop up without touching the buttons?
It's very infrequent, but kinda annoying...
And yeah, the Display Port cable in the box works fine for me.
Mine should be showing up from Amazon in the next 2 days, can't wait! Coming from an LG 27UD68 (4K IPS 60Hz) that I love, I feel this will be a great compromise between refresh rate and color accuracy. I tried the Dell S2716DG about a year ago and returned it the next day, could not get decent colors and the banding was awful. I loved the smoothness that g-sync added and I don't care for the flashy gaming monitors out there from Asus and Acer so I never replaced the Dell after I returned it.
somewhat used to both, I use 2 x 27" 1080 dell va panels at work, but good insight none the less.The 32GK850G is about as good as it gets without going for the $2,000 gsync monitors. Just keep in mind that VA panels have weaker viewing angles and it'll be even more noticeable on a 32 inch display. Also PPI will be significantly lower than a 27 inch 4k.
To add to this: I have a 27" 1440p next to a 31.5" 4k, and the low PPI of the 4k monitor is still annoying- I'd want a minimum of ~35" 16:9 for 4k for comfortable daily use.
27" 4k would be scaling at a minimum, and scaling is still goofy- I turned it off on my 31.5" 4k. It works, but the comfortable scaling levels are blurry.
I think that a 31.5" 1440p monitor would be just about perfect.
Same, even with a new 15ft DP cable, every over day the screen controls pop up while I'm mid game (for a few seconds), no idea why.
But didn't happen with the black screen flashes on the crappy 16.5ft DP cable...
Hope it keeps coming down. $599 USD would be great
