31.5" 2560x1440 165 Hz VA G-Sync - LG 32GK850G
Discussion in 'Displays' started by Vega, Nov 9, 2017.
  1. DooLocsta
    DooLocsta [H]ard|Gawd
    1,451
    Jan 26, 2005
    Change https to http and your images will work
  2. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    I took it directly from imgur, weird I can click the links just fine. I will repost the comment:
    Can anyone post their impressions on their monitor's BLB and/or clouding? A photo would be helpful. I had to get a replacement for a shipping issue, but the original one showed no BLB or clouding (maybe because it wasn't warmed up yet) but this one has significant issues in my opinion, based on what I have read about the lack of any BLB or clouds from both users and thorough technical reviews:
    http://i.imgur.com/Y6vTsIO.png
    http://i.imgur.com/U6pRkRR.png
    http://i.imgur.com/swUuqx9.png
    The circled areas are where it's really noticeable and not just due to the angle of viewing for a VA panel. Thoughts?
  3. AstroCat
    AstroCat Limp Gawd
    145
    Mar 9, 2006
    What camera settings did you use? I think I noticed maybe a tiny bit more BLB in the bottom left corner on my 2nd monitor. The first one had dead pixels right in the middle of the screen so I swapped it out.
  4. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    For the darker photo with less exaggeration, I used auto on my phone but adjusted the light/brightness manually to lower it to what my eye seems to see.
  5. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    8,197
    Jun 13, 2003
    Freesync monitors aren't going to improve in VRR effectiveness, and Nvidia is only doing it over DP, not HDMI.
  6. JackCY
    JackCY n00b
    19
    Nov 14, 2018
    Limited refresh rate on some monitors is caused either by the EDID not having the definition of the desired refresh rate in no sync mode or your cable is bad and even if you can select the higher refresh rate it won't hold or it will skip, usually it won't even switch to it. Of course the case of having the definition but scaler being too slow to handle it can also happen but then it would do that even in adaptive sync mode.
    I have no had any issues running 1440p 144Hz on (GTX 1060 6GB): AG322QCX, XF270HUA, C27HG70.
    165Hz 32GK850G
    75Hz Q3279VWFD8
    There is someone who had 850F and 850G, they kept the 850F, you can dig it out on OCN, default sharpness on 850F seemed blurry same as 850G and I never got a photo of how the sharpness is after adjusting it in OSD on 850F.
    My gallery: https://imgur.com/a/bDFVmjz
    The unit was reasonably flawless for and LCD when it comes to BLB. And many are reported by users as such but not all.
    Rayz unit looks quite bad. This is an LCD that has a reasonable chance of being nearly "flawless" when it comes to BLB and even it's VA glow is lower than Samsung's VA. Sadly, duds of all kinds still exist and there is some lottery as always with monitors.
  7. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    Got a replacement. Worse clouding in all the corners, but the center ones (in the same spot) isn't as bad.
  8. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    https://imgur.com/a/GyG9u4M
    Camera exaggerates on the brighter lit clouds image, but the general areas are shown. The darker screen image is more what it looks like in actuality, with the center clouds a bit more visible.
    The center clouds are in the same spots but they are significantly less noticeable. However the corners, especially the top right, are pretty bad. I think the top right corner is as intense, if not more intense, than the centered one from my previous photos. The corners from the first model were fine and the discoloration was just due to VA angles. But this is legitimate clouding on the right corners for the most part.
    Not sure what to do or which to keep. This is my 4th from Amazon, and for this specific replacement request they seemed to be cautious and said they wanted to investigate before sending me another one due to repeat returns. The first 2 had loose back plastic and I probably should have just dealt with it but it seemed like shipping damage to me (Amazon wouldn't provide any shipping box or cushioning). The 2nd also came in what seemed to be an opened package that was retaped (poorly) and sealed. I hadn't checked their cloud/BLB issues at the time, and then the 3rd was the original photos and 4th is this one. I should have kept the first one and probably had better luck. Dumb of me.
    Even the LG logo was printed pretty crooked on this model. Not really a big deal but it's shocking how much went wrong with this one :/
    Oh and scratches galore:
    https://imgur.com/a/72nT1Nh
  9. Ark :o
    Ark :o Limp Gawd
    223
    Dec 7, 2006
    Any way to disable DDC/CI on this monitor? I'm willing to modify a cable if I have to.
  10. riffcho
    riffcho n00b
    35
    Mar 13, 2013
    I guess you can't say you had a proper purchase unless you have exchanged at least 3 times. And at the end most are getting returned unit at least once. You guys are doing it for fun.
    I have not bought a monitor before checking it personally. Probably paid + 3 to 5% more sometimes.
    And in my country I bought this for 700 eur (VAT is 20%, 30 eur discount for not perfect box), the F model is about 730 eur. Go figure.
  11. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    It is not fun that I keep getting defects at all. Scratched screens, shipping damage and issues, and excessive clouding and bleed on a model where most tests report minimal backlight intrustion. They even misprinted the friggin logo on this monitor. That is a minor nitpick but it just adds to the janky experience I've had.
  12. riffcho
    riffcho n00b
    35
    Mar 13, 2013
    Had my GB 2080T away for repair and was using Intel in-bed graphics. One way to expose ghosting on this monitor is snooker/pool game - red balls on green table , massive (virtual pool 4, WSC2009). G-sync makes it virtually unnoticeable (165 Hz/faster). You really have to look for it and it is still hardly visible, for me. Sadly WSC2009 appears to not work with G-sync (or because it has 100 Hz max in graphics settings) and still has massive ghosting effect.
    PS. Apparently I was quick in my conclusion. Still pretty noticeable although not as much. These specific games really show the ghosting well on this monitor. My Eizo (IPS) has very minimal, visibly lower.
  13. JackCY
    JackCY n00b
    19
    Nov 14, 2018
    Most monitors have that option in OSD, not sure why you would need to change the setting to ON or OFF. I don't use these apps that allow monitor control via software, if you do then turn it ON and usually it defaults to ON.
    Not doing it for fun, when all the units have stuck pixels, dust, crazy BLB, visible scratches, ... what is one to do other than to send it back to seller when we have that option and I would NOT buy any monitor without having that option since the quality control on monitors is non existent and seller do not pressure manufacturers to improve the quality. They simply sell it all and then deal with massive returns of defects.
    Would gladly look at a monitor in person like in the old days when buying it locally but the large local shops do not offer this, you order online to get the 2 weeks return no questions asked and then pick it up in person and always when asked if they could power it up they say they cannot (they used to do that 10 years ago) and literally tell you to take it home and if you do not like it to return it, they tell you that so that's what everyone is doing. Sellers also love to reseal returned products with their own sticker and try sell it as new instead of as open box, of course most returned monitors are returned due to a defect, personally I always tell the seller monitor is defective and how so that it is not resold but is RMAed with manufacturer/distributor by the seller. But I think most people simply return it and do not tell the seller why, the law says you do not have to say why you are returning which indeed is better for customers but sellers are too lazy to test a monitor before reselling it again so these defects circle around resold.
    Yeah I've had factory sealed C27HG70s that had rattling internal board, literally the board inside was loose, some had hard scratches on plastic, AG322QCX had the packaging soft bag pattern imprinted on it's front surface and good luck getting that out (was visible under certain lighting conditions), 32GK850G broken internal conection IMHO of the Gsync board causing half of screen to artifact with green+red vertical lines, ... the rest are common pixel defects, BLB, excessive glow, ...
    Amazon does get investigative when you return a few monitors in a row, they really do, but I've had no problem writing them back the real deal, why the monitors I purchased were returned, that I have stated on all of them reason for return being defects, inadequate quality, etc. None of which were my fault and they should deal with the product manufacturer to improve quality.
    Sadly you only really get to try 1-2 monitors before their automatic system picks you up. It does start to trigger when you return about 5 units in a row and didn't purchase and keep anything in between.
    You have to remember that it is not your fault that the product you received is faulty, defective, etc. it's manufacturer's fault and keep sending them back and explaining that to the seller. I also take photos and send them photos of the defects when possible, that way it can be easier to persuade the sellers to see your point.
    I think you can get this flat AUO 31.5" VA in a decent quality, they do exist, unlike M270DAN2.x and Samsung curved VA panels. Problem is that even if you get a good one there are other things that can go wrong... scratches, broken internals (such as mine had), ...
    Buying monitors is a nightmare with this non existent quality control.
    Got this one Q3279VWFD8 and it's perfect 1st try, kept it, had enough of the 144Hz panels lotteries. One should not be required to return 5+ monitors when trying to get a defect free one.
    The quality control on monitors these days is as follows: does it turn on? Package it and sell it. What ever automated QC they have using cameras etc. if using it at all is so bad it does not catch obvious defects.
    Some of the defects are pure mishandling by workers, when it comes to scratches on panel, housing, ...
  14. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    I think most people don't care, sadly, about things they don't always notice, like BLB and clouding in dark rooms and scenes, or even just scrapes on the screen itself. But this is at least a $650 purchase...That is a lot to ask for for a product that doesn't feel premium when the LG logo itself isn't even printed properly.
  15. Ark :o
    Ark :o Limp Gawd
    223
    Dec 7, 2006
    This one does not. I have a very specific use case where I do not want the monitor to disconnect from the system because it breaks an app that I want running overnight/while afk. Disconnect = number crunching stop = unhappy me.
  16. chenw
    chenw 2[H]4U
    3,987
    Oct 26, 2014
    Well, after some really long thinking, I ended up not waiting for the drivers and got the 32GK850G.
    Kinda disappointed at how little difference the increased contrast made, but otherwise I am not too disappointed at the monitor, the colours came closer to my BL3201PT after calibration than my PG278Q did, so no real complaints.
  17. Will0w
    Will0w n00b
    16
    Dec 10, 2014
    Very late to answer but have you tried to turn off Deep Sleep from monitor settings?
  18. Fuzzy_3D
    Fuzzy_3D Limp Gawd
    166
    May 27, 2007
    In the industry we call those "gashes", when material isn't just marked or grooved but damn well removed. :confused:
    I had to return my 1st one, and I'm not even that picky, but stuck pixels are an out right NOPE!
  19. Fuzzy_3D
    Fuzzy_3D Limp Gawd
    166
    May 27, 2007
    Will try that. It does appear to be a DP issue.
  20. elvn
    elvn 2[H]4U
    3,026
    May 5, 2006
    not exactly what you ate looking for but I highly recommend checking out displayfusion pro if you haven't before. It remembers app window sizes and positions incl on which monitor and you can also make hotkeys for quick window movements to your favorite sizes and locations. When I activate my 43" 4k VA tcl in my array the windows are all over. A few hotkey prrsses they are flying to where I want them.
  21. jdj9
    jdj9 n00b
    1
    Jan 25, 2019
    I own this monitor for a while now and am quite happy with it, despite its few cons. Can someone recommend good calibration settings to improve image quality? Thank you.
  22. amd7674
    amd7674 [H]ard|Gawd
    1,541
    Jan 1, 2007
    Try this. You may try Gamma 2 instead of 3 (personal preference).
  23. elvn
    elvn 2[H]4U
    3,026
    May 5, 2006
    I've posted several permutations of tweaked settings vs my other two monitors and my oled tablet by eye.. not using calibration hardware and software but using calibration images on all of my monitors at the same time as well as 4k colorful art photos to get to where I'd like it. My biggest complaint was getting the whites to actually look white and not off-colored at lower black depths, especially in relation to my other monitors.
    I recommend at the minimum turning up the nvidia driver applet's desktop digital color vibrance a few percent on the desktop and editing your RGB values in the monitor's OSD..
    ..and I highly recommend using nvidia freestyle which pops up a sidebar of simple settings sliders on the fly. It's like an EZ mode of reshade built into the nvidia suite, written with help of the author of reshade.
    In games , freestyle has a sharpness filter you can bump up slightly (which windows desktop/apps notably can't utilize) .. as well as a color vibrance filter and brightness and contrast filters. I mainly use those but there are several others. Freestyle remembers the settings on a per game basis so it allows you to have different settings for different games. For example the brightness/contrast sliders on a really dark game, or more/less sharpness and color saturation for different game genres and environments. Since those filters are only active in games, it keeps your tweaked-for-desktop usage base settings untouched when you are back to the desktop after exiting a game too.
  24. riffcho
    riffcho n00b
    35
    Mar 13, 2013
    Has anyone experienced display disconnects from time to time on DP connection? Windows 10 onboard graphics i7-6700K, GB Z170 motherboard? Windows sounds like losing and finding a new device but no notification.
  25. Will0w
    Will0w n00b
    16
    Dec 10, 2014
    Try lowering refresh rate. Your integrated graphics probably can't handle higher refresh rates at 2k. Also if monitor has overclock enabled, disable it.
  26. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    So wtf is this on my new purchase of this monitor from B&H?
    It looks like a bruised spot, it's not on the surface and not a mark I can clean. It's below the physical screen.
    Trust em it looks way worse than this. It's the first thing I noticed and I see it casually just glancing at the monitor, rather than it being a dead pixel I search for.
    edit: there are two of these types of clusters/spots.
    http://i.imgur.com/oQD2jvO.png
    This monitor also has the worst parts of the previous 2's BLB combined. It makes the same exact pattern, I am starting to think this is very much a manufacturing defect. Without hesitation I can tell you there will be prominent clouding slightly above and to the left of the screen, slightly below and to the right (these 2 are massive btw), and a huge chunk on the top right corner. The shape and patterns are exactly the same.
  27. Digital Viper-X-
    Digital Viper-X- [H]ardForum Junkie
    13,500
    Dec 9, 2000
    private images :p
  28. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
  29. DooLocsta
    1,451
    Jan 26, 2005
  30. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    Is the red embedded one visible now? It's the pic with the most obvious example. I have at least 3 clusters like this that are visible from my sitting distance, already requested a replacement. Huge disappointment in addition to realizing the clouding issue that is just inherent in this model it seems.
    Ah and another one with what is either a dead/stuck pixel or dust under the screen. I hate buying new equipment :/
  31. RayzTheRoof
    RayzTheRoof n00b
    12
    Jan 8, 2019
    Update: found at least 4 pixels with dust or something making them look black/dead. Can't see anyone getting a good panel if the issues are this consistent.
  32. AstroCat
    AstroCat Limp Gawd
    145
    Mar 9, 2006
    Just a quick follow up, I've had the LG 32GK850G for over a month now and I'm super happy with it! :)
    I mounted it on my desk using the AmazonBasics Premium Single Monitor Stand and it's positioned perfectly for me.
    I've been nothing but impressed with the image and performance and feeling totally satisfied I made the best choice for my gaming needs given 1440, 31.5", G-Sync, etc...
    I did have to get a second monitor though, the first one had a dead pixel right in the middle! Luckily the replacement was image defect free.
    I used the TFTCentral ICC profile and their settings but I upped the brightness a bit more for my tastes.
  33. DG25
    DG25 Gawd
    543
    Dec 15, 2006
    How does 1080p content look on this monitor? How good or bad is the upscaling? Some older games or indie 2d games don't support higher than 1080p resolution.
  34. Lepardi
    Lepardi Limp Gawd
    139
    Nov 8, 2017
    G-sync scaled 1080p always looks blurry and bad. But since it's 31.5", you can basically use it as a 24" 1080p monitor in 1:1 scaling for those games.
  35. Fuzzy_3D
    Fuzzy_3D Limp Gawd
    166
    May 27, 2007
    It sounds like the key to buying one of these monitors is to get it from an outlet that provides hassle free returns, odds are 50-50 it'll have a defect or you won't like the light bleed/color vibrance/pixel size.
  36. IdiotInCharge
    8,197
    Jun 13, 2003
    This is a thing that doesn't exist...
  37. Will0w
    Will0w n00b
    16
    Dec 10, 2014
    To me it sounds like the same few people keep getting defected ones. Got a defect free monitor the first try.
  38. Lepardi
    Lepardi Limp Gawd
    139
    Nov 8, 2017
    G-sync chip does the scaling on all g-sync monitors.
  39. IdiotInCharge
    8,197
    Jun 13, 2003
    Why do it on the monitor and not on the GPU...?
