3090 extra 8pin power help (ghetto rig)
BinarySynapse
You need three +12v wires to feed a PCIe 8pin. The two molex to PCIe 6-pin only provides power from two.
Emission
This, plus you would want all 3 of those wires coming straight from the PSU, when in this case they're likely going to originate from a single wire, and PCI-E power wires are usually thicker than what you'd find going to a molex connector, to cope with the extra current that the device would be pulling down. Highly do not recommend.
Just get the appropriate cable.
OpenLooper
thanks guys, i figured this was too ez to be acceptable lol. Just ordered a proper modular cable now
OpenLooper
ooook fixed it properly :) (yes ino i need to work on my rgb config)
