Viper87227
- Jun 2, 2004
Actually you can if there are options to do so. The 320 mb 8800gts was obsolete long before the 640 mb version was. The 256 mb 8800 gt was essentially doa compared to the 512 mb version. The 6 gb 1060 can run higher settings at much smoother performance than the 3 gb version. The 8 gb 570/580 allows much higher textures and such than the 4 gb version.
My knowledge may be a little rusty, but aren't some of those examples different in more ways than just memory? The 1060, for example, also had less CUDA cores, which is probably more responsible for the performance gap.
Likewise, my understanding was generally that the additional VRAM was meant to handle an increase in resolution. For example, with the 580, one would probably be fine with the 4GB model at 1080p but better served by the 8GB model at 1440p, no? Right now, the prominent resolutions were gaming at are 1440p and 4K (or the ultrawide in-betweens). If 10GB is enough for the 3080 to handle 4K (and according to Nvidia, it is), they why add more VRAM? Nobody is gaming at 8K, and I really don't think it's on anyones radar right now. Even if it were, I don't really think the memory is the difference between this being a 4K GPU and an 8K GPU... even Nvidia's claims that the 3090 is an 8K GPU are a bit dubious IMO. These cards aren't powerful enough for that (and they really don't need to be).
There might be one of two one-off examples of games that would be served well by more than 10GB. I expect for the functional life of the 3080, they will be very few. Few enough to not justify the cost... which is the whole point. If you want to go balls-to-the-wall, the 3090 is waiting for you. For the rest of us minding our wallets, better to trust that Nvidia knows better than we do, and matched the appropriate amount of VRAM to their GPU.
