3070 FE w/12 pin dongle
DarkSideA8
Just got mine today - TYVM, BB - and noticed it has a 12 mini-pin dongle that attaches to a standard 6 pci +2 pci (aka 8 pins) lead from the psu.
What is the purpose? Feeding power to different channels?
Why not just feed the 8 standard directly from the psu?
cdabc123
The purpose is for fun. All those pins are tied together on the card. 6+2 is only 3 12v pins and 5 ground pins. A 8 pin would be preferable as its 4 12v and 4 ground and is rated for more watts as a result
Sir Beregond
On the 3070 it doesn't serve a damn bit of purpose.
t2uciet
Scalper in FSFT
No purpose lol. I ordered a replacement to make the cables cleaner. For the 3070, it isn't so bad though. The 3080/3090, it's a Y adapter though so it's gets ugly.
I ordered a new power cable from Corsair.
Edit: My Zotac card in pic comes with ugly adapter.
DarkSideA8
Total side-bar question (but still about the 3070)
-- Since installing this, whenever I am in a game, I get a constant small FPS counter. Green. It's not the one that you can select in the GeForce Experience overlay; that one is much bigger. This is like a small, 14 point font distractor that I can't figure out how to make go away. Way up in the upper left corner. Disappears in desktop mode (web browsing, word, email) but when I initialize a game, there it is.
Ideas on what setting I may have hit?
DarkSideA8
Is it MSI Afterburner's? DarkSideA8
I don't know. Don't think so. I used to have a MSI card on the system - but I haven't used AB in years. Did a clean install for the 3070 driver yesterday.
The big change, aside from the new card, was going to the NV Experience (free year with card) where previously I just used the free app and manually updated drivers. Also went from dvi to DP.
I half wonder if I accidentally pressed something on the monitor (it displays a steady 60 fps) - but AFAIK, the HP ZR24w does not have an FPS function.
It's weird
[L]imey
It's weird
Afterburner will run no matter brand card you have.
Make sure it's not running in the system tray.
German Muscle
sounds like Steam FPS counter
Why? The very short mini-12 connecter that came with the FE literally matches the Corsair black mesh cabling.
Edited my original post above for clarification. My Zotac card comes with a x4 6pin adapter. I have to run x4 6 pin cables from my psu. Made more sense to run x1 power cable from my psu.
