So heres the situation I'm in...
I just got a new apartment and I have my office on one side of the house and my living room on the other. Running a wire is not going to really be possible, because of a vaulted ceiling issue and that side of the house being completely closed off in the attic (which i DONT REALLY have access to, although i can access it).
The HTPC in my living room will stream movies from my server (in my office). I have a Netgear Wireless-N Router that does up to 600Mbps (if the adapter I use, can handle 2x300Mbps connections).
Now... my question is this
1) Does anybody make a wireless card that has the 2 radios/antennas on it, so i can do 600Mbps...
2) If i only get 300Mbps via a regular wifi... will that be sufficient? Meaning, will that 300Mbps wireless be faster then a regular 100Mbps network connection (my switches are Gigabit but i stream movies in another bedroom via 100Mbps right now just fine).
So thats my question... WILL i notice a diff with streaming movies, right now im hardwired so theres no delay at all, will there be one with 300Mbps and can i get an adapter to do 600Mbps since thats what my router CAN do.
