In November I lost an HP LP2475w and a Samsung 2343BWX, I replaced them, along with a still working LP3065, with HP 3 ZR2740w monitors. Tonight, one of the new HPs just died.
Everything is hooked up to an APC SUA1500RM2U UPS. Voltage looks good, currently 118.7 and 59.9Hz as measured by a Kill A Watt meter. I haven't had any issues with any hardware on this UPS, just the monitors.
I've tested the monitors on other machines with different cables, and they are definitely not working anymore. I opened the first 2 monitors up, and examined all of the boards, and I didn't see any bulging caps, or burn marks, or other physical signs of component failure.
In late November, after the first 2 monitor failures, for unrelated reasons, I upgraded to a new PSU, motherboard, CPU, and RAM, keeping only the 4850x2 and two sound cards from the old system.
I'm pretty convinced my Sapphire 4850x2 is somehow causing this. And I'm going to replace it ASAP...
But how could the signals carried by a Dual Link DVI port kill a monitor? It's possible that it was indirectly caused by a driver update. I was running 12-18 month old drivers with no issues, and updated them in Late October early November, at the same time I updated another system's Radeon drivers for BF3.
There seems to be some correlation with the failure occuring at wake from sleep time. The LP2475 displayed something for 20-30 seconds after waking, and then it was dead. I wasn't there when the Samsung died. The new HP also seems to have died around the time of waking from sleep. At least it was working perfectly 1-2 hours before I attempted to wake up the monitors, it died, and it's twin on the other side woke up.
Any ideas what's going on? Has anyone else experienced similar issues with similar hardware?
