Wonder if that's why he didn't answer me when I asked how many PBW were left on these cards? I'm sorry for you guys, but glad I didn't pull the trigger on this one!I got a dud as well.
Guess I dodged a bullet.
[root@nfskvm ~]# fio-status -a |grep written
Physical bytes written: 26,125,592,499,616
Physical bytes written: 6,335,470,649,880
You can bump the PCIe Power limit threshold to 75 to improve performance (seems to be for smaller files)
Driver should auto-detect the supported slot power configuration, but that's usually in server boards. In the cases that it doesn't the card limits it 25W for writes, which will hamper performance, especially for large files where the block sizes and throughput will be larger.Yeah, I thought I got an okay deal with a 69.something% when this thread was new.
Just checked, and it's 69.35% (also being used as a game drive)
https://www.dell.com/support/kbdoc/...isk-fusion-io-iodrive2-to-improve-performance
That is a LOT of writing you guys are seeing on those drives!!!
I've used my 3.2TB one, since this thread began in 2020 as my Steam, GOG, Epic, and Orgin games drive.
I'm down to a whopping 99.38% life left which is barely below where mine was when I bought it! (99.77% was what my original life was) Which is less than 1/2 of 1% life exhausted in nearly 3 years.
Sorry to hear you got some worn out duds!
These aren't the greatest deals they were back when the thread started and SSDs of this capacity were much more expensive, which was when I got mine. That said, some of us weirdos are big on reliable storage with a (very) long term endurance potential and the consistent performance offered by MLC and enterprise-grade hardware. Mine does just fine as a game drive and my video/photo editing scratch drive. The speeds aren't stellar by any means, but they aren't a hindrance, either. What I really like in my SSDs is that I buy knowing I'll be able to use them in a rig with a long use life and then move it to the next one without worry.Thought about pulling the trigger, but then after reading your usage perhaps the endurance is excessive for average users like me.
100 TBW after 2+ years of heavy usage,
That means a decent$80 Teamsgroup 2 TB sata ssd with 1.6PB endurance will get me 16 years of heavy usage....
So still an awesome drive, but probably not ideal for low power users like me. My windows boot drive after 2 years has a whopping 2 TB written! That 512 GB 970 evo will last long after I don't need it anymore.
It's designed to be installed in a rack. For best performance, make sure it's set to 75W power (it doesn't go anywhere close to that) and the controller has good airflow over it.Ehh.. this thing throttles quickly, guessing temperature. copying movie files from my Samsung 970 or inland m2, write speed gets cut to 10% almost.
