2x120mm Noctua or 1x200mm Cooler Master?
kensiko
I have had a HAF912 case for the last 10 years and I like it. I have multiple fan options, however for the 200mm fans I can only install a Cooler Master one, the others 200mm do not fit. I only have 1 200mm and it's not that great. All the other fans I have are 120mm. I was looking to replace all my fans by high quality low noise fans and I think the ones from Noctua are what I'm looking for.
However Noctua confirmed that their 200mm fan do not fit my case and I have 2 places (front and top) where I can install those 200mm fans. For the top fans, I have 2x120mm. Should I just put again 2x120mm from Noctua or get another 200mm from Cooler Master ?
Nobu
I have a Thermaltake fan, 180mm iirc, and it's pretty quiet. You might get better airflow with the noctuas, but I think noise would be about the same between the two.
kensiko
ok but would it fit the holes for the 200mm in my case ?
Nobu
Probably not. Was just trying to give you an idea of what to expect if you got the noctuas vs the 200mm coolermaster.
