Hi Guys, I have a R9 295x2 120mm radiator sitting in the top back 140mm exhaust slot on my case.
I was considering upgrading to two HP-14 140mm fans in push-pull, since they have both 140mm and 120mm replaceable rubber mounting corners, and then using the "duct tape" mod to ensure an air-tight seal for the push-pull 120mm radiator so no air leaks out the sides.
The 140mm and 120mm fans are the same price, and the 140mm has superior specs.
Thoughts?
I already have some matte black "gaffer" type of duct-tape that is high quality and wouldn't even be noticeable, and I have no window on my case anyway. I just like max cooling and quietness.
Thoughts?
