cokewithvanilla
- Aug 28, 2013
Hello. I finally decided on my monitor setup (2x Samsung 40 inch MU6300) and i need some GPU advice. I will probably wait 2 weeks to see if vega is released, but if not, I am definitely going nvdia.
2 980ti's can be purchased in the used market for the same or less than one 1080. In synthetic benchmarks (passmark), the 980ti scores extremely similar to the 1080. In some examples, you see the 1080 beating out the 980ti significantly in DX12 applications
anyway, I would be running this mainly for day trading, but I probably would also run a second boot and maybe play some games, but on just ONE of the screens. otherwise, I will be dividing up the 2 screens into 8 1920x1080 monitor slices.
the build so far seems to be i7-7700k, samsung 960 evo, ASRock Z270M Pro4 (or possibly ROG STRIX 270G), 32gb coarsair vengence, 1000watt corsair cpu, corsair carbide 240, corsair 100i v2
my only concern about getting 980's is the spotty info I am seeing on 4:4:4 4K@60Hz. ... from what i can tell, it can do it over DP but not HDMI, so for the tvs i will need an adapter. Other issues is I do not know about color depth, and having had 2x980's (not ti) before, I know SLI has its issues... but that would not affect me unless in gaming. 2x1080's or 1080ti's are out of the question. around $500 is all i want to put into the video side of this computer.
