Pretty standard system, 4790K overclocked, four sticks of ram, SSD, four hard drives, and currently a 295x2 powered by a Seasonic X-1250.
http://www.seasonicusa.com/NEW_X-series_1050-1250.htm
Does anyone know if this can support two 295x2's?
Each card IIRC needs 50amps on two up to 28amp 8-pins, and both would take about 1000 watt in theory. I know one works fine even though technically my PSU is rated for 25amps on each 8-pin... if its not getting enough power, I certainly haven't been able to notice any performance issues from it.
I see their recommendations are all 1500 watt PSUs: http://www.amd.com/Documents/Select...for-the-AMD-Radeon-R9-295X2-Graphics-Card.pdf
Thoughts?
Reason I ask is there is a killer deal on a Saphire 295x2 for only $550, but otherwise I might go hybrid crossfire and add a single air-cooled Tri-X 290x.
Thoughts?
