2gb ram, 2x1gb sticks or 4x512
socK
Probably going to build a new comp within the next few weeks and probably going with 2 gigs of ram. My first thought was to get 2, 1gb sticks, then i read stuff about some people using 4 512 sticks. Is there any advantage with 4 512 sticks?
Thx for your input
socK
You may get a little more dual-channel but, eh, that takes up all your slots. I'd go with 2x 1GB.
Yeah i would just go with 2-1024....there no advantage with 4- 512. Only it may be cheaper if someone has 2-512 already.
For me i have 2-512 right now...thinking about switching to 2-1024(I CANT RUN FEAR HOW I WANT TO) and using my current ram for another rig.
No doubt about it: 2x1 GB, esp. if you don't already have 2x512 MB RAM sticks.
Wasn't there a huge thread on 2x1 vs. 4x512? I'll have to look for it.
Edit: I did a search and found this thread.
(cf)Eclipse said:
rig in question? a64's dislike 4 sticks of ram in almost all cases ;)
About the memory controller, what happens is that Athlon 64 processors have a limitation. When four DDR400/PC3200 memory modules are installed on the system, they are accessed at 333 MHz and not at 400 MHz. This was corrected on Venice and San Diego cores: on CPUs based on these cores the processor accesses the four memory modules at 400 MHz.
http://www.hardwaresecrets.com/article/239
On my X2 4400+ with 4x512 I have to manually set it to 400mhz, but it works fine. I also tested my system with 1T and 2T timings. I had no no difference in FEAR and only a 50 point gain with 1T in 3dMark05.
don't forget that you'll have to raise command rate to 2T too. also, i've seen revE cpu's not be able to do 200mhz with 4 sticks in. whether it's the limitation of the memory controller or the mobo.. i can't tell without actually playing with it myself. ;)
