http://blogs.nvidia.com/2011/06/download-whql-certified-geforce-r275-drivers-now/?sf1548210=1
Sorry I can't post more info but I'm posting remotely. Enjoy.
ManuelG@Nvidia Forums said:Just wanted to let you all know what we will be releasing an updated driver this week but because the check in that improves the overall game performance could not be tested properly in time, it was not checked into this driver branch (there was a potential that it could break compatibility with other games). The fix won't be in until the June driver. There is another fix that was checked in a while back that will address the slow performance when a user enables 3D Vision, even if the user has disabled it with this game. That will be in this weeks driver.
With Release 275 drivers, the 3D Vision Controller driver is now included with all GPU driver installations.
so we don't have the option to not install that now? I thought that 3D driver caused issues in games like the Witcher 2.
okay thats good to know, thanksYeah, they sometimes caused hitching for me in games like Rift and others if I had the 3d vision controller driver installed, even though I'm on a 2560x1600 S-IPS panel display (2D)... leaving them out of the installation solved the issues. However they do note they fixed a performance loss when it is disabled, so perhaps that's what they are referring to.
EDIT: Just downloaded the drivers, you CAN uncheck (under custom install) the 3d vision stuff to not install it. So, nothing's changed.
cannondale06 said:With Release 275 drivers, the 3D Vision Controller driver is now included with all GPU driver installations.
Well, there's conflicting reports on whether the 3D issue actually is fixed in this driver release - and some seem to be having the experience of this driver release actually degrading performance in the game.
I've got plenty of games to play, so waiting for better SLI utilization for this particular game isn't having me stop gaming because of it or anything like that.
I'm sure you guys have read nVidia's official responce on the matter of The Witcher 2 and their 3D Vision driver:
http://nvidia.custhelp.com/cgi-bin/nvidia.cfg/php/enduser/std_adp.php?p_faqid=2995
Basicly, nVidia is saying that the problem is in the game code, and not their driver. They got a temporary workaround for it in this driver release, and are working with the developer to get it fixed properly in the game code.
As to weather the problem realy is in the game code, or in the driver... who knows, its all finger pointing. But at least nVidia seems to be willing to work with the CDProjekt devs to get whatever the issue is resolved.
when is the last time you installed an Nvidia driver? pick what you want to install and just choose the clean install option. that uninstalls the old driver for you before installing the new one and no rebooting required.can we install this right over our old driver, or do you have to uninstall first?
These drivers are garbage. Dragon Age 2 displays all kinds of wierd shadowing anomolies. Rolling back to 270.61 fixed that shit.
I'm doing a clean windows 7 install with two GTX460's with this update, however, I think something is up. The maximize 3D option is greyed out....but it still sees my two cards.
My two video cards are in perfect working order and these are the first drivers I've attempted to install. What is up?
UPDATE: Upon an additional restart....it now gives me the option to maximize 3D...however...when I do this....it instantly gives me a BSOD.
Again....I have not installed any other drivers or any windows update. I'm running MSI Big Bang BiosV1.6(most current) and am 100% my bridge cable and both my video cards work.
Don't know if you solved your problem, but I had issues with SLI even showing up and it was due to a conflict with the driver for the Realtek LAN chip on the mobo. The MSI Big Bang has a Realtek LAN on it, so to check you may just want to disable the LAN on the mobo (either in device manager or through the BIOS) and see if the problem goes away.
If that fixes it you probably want to go to Realtek's website and hunt down the latest driver they have for the chipset. In my case, neither Windows Update nor Gigabyte (my mobo manufacturer) had drivers based on the latest Realtek driver, and the older drivers they both had were giving me SLI issues. Not sure if Realtek explicitly noted compatibility changes in the driver changelog, but that's what worked for me.
The problem still persists. I've disabled LAN controller in bios. I've also tried different SLI cables, and also plugging in JPRW4 connector. Currently my windows 7 ultimate x64 have all of the updated drivers minus the disabled LAN controller option. My MSI Xpower is updated to v1.6. I've read a few places that lowering clock speeds on my video card and ram may help but i really really doubt this is the issue. My 12GB corsair gt is running at stock speeds as well as my gigabyte gtx460's. Is there anything else I'm missing? These headaches makes me want to trade these two gtx460s and get a single gtx580.....please help.
Seems like it's down to good old troubleshooting, then. You say you're 100% both cards work, but I'll just ask the usual have you tried installing each card by itself in the main slot (ie. install one, see if it works fine in the main slot, then uninstall the drivers and swap in the other card and reinstall the drivers and see if it works?).
Also, specifically which Big Bang mobo are you using?
