Bluesun311
- Sep 21, 2013
Yes
My "ultimate pixel perfect" did indeed come with no dead pixels and OCS to 120hz. Unfortunately, it just doesn't fit by about 1/4" in my desk and I absolutely can't change my desk. Argh... I think I may need to return this or sell it. I almost want to forgo my desk entirely and just set up on the floor this display is so nice![]()
Okay, please excuse my ignorance. I currently have the Asus VG248QE 144Hz 1ms and I have been eyeing the new Asus ROG SWIFT PG278Q 1440p 144Hz 1ms and the QNIX 1440p.
My issue is understanding the numbers if someone can please help me out.
Just as an example, say the Qnix monitor I buy has a refresh rate capped at 96Hz and measured response time is 8ms.
A new frame is rendered every 1 / 96 Hz = 10.4ms.
At 8ms GTG response time, wouldn't there be some time left (10.4ms - 8ms = 2.4ms) that would stop any ghosting/motion blur? I see in the FAQ it says that there is noticeable motion blurring in FPS games with the QNIX QX2710.
I understand that there are no real industry standards when it comes to measuring response times. I would just like to know why, if the pixel response time is less than the refresh rate, how is it not sufficient enough for professional FPS use (i.e., no motion blur)?
Best regards and thanks in advance!![]()
I posted on OC forums but didn't receive any replies yet. I'll repost here if anyone could respond. My previous question was very vague.
I read on another forum (or maybe it was here) the vesa mount on the back was kind of wonky and didnt actually fit third party mounts. Looking at getting a triple monitor mount for my X-Star and two other 23 inchers....has anyone successfully installed a different mount and had it work properly?
Yah that's a fair question, it's one that I ask the guys that won't accept anything but Lightboost/Turbo240 anymore. But it's a very personal thing. Motion blur isn't as important or just isn't as apparent or noticeable to some people. Some people play games that make motion blur much more of an issue. If you are playing strip poker online it's not going to make much difference
But you specifically said FPS games, if 8ms pixel persistence will produce noticeable motion blur--yes. It will. How noticeable? Well, it's 7x as much blur as with Lightboost on your monitor. How much is that? Idk, not much it really doesn't bother me lol. So that's how I end up in arguments with people over Lightboost, which makes my eyes water and that's not good when you're trying to pick out where your pit-box is. Can't be good when you're trying to snipe a guy in the neck, either.
The OC monitors DO have noticeable motion blur during movement of the camera, or just tracking objects. The faster the motion, the worse the blur. So if you are playing FPS games for money, the 1ms TN with lightboost is hands down what you want to have.
The explanation really is simply that with your VG248QE using 120Hz with Lightboost hack on--there is literally almost zero motion blur. How? It's being hidden from you. The backlight is being turned off and back on again every single time there is a refresh cycle (blocky movement at highspeed still looks blocky to your brain, using the strobe tricks your brain into interpreting this as no longer blocky). This also hides pixel transitions (colors changing on stationary pixels). Anyway... I play adventure games and I occasionally take the old Logitech Force Feedback wheel out for a spin, but I'm not competitive anymore, and so a good balance between emmersive color and emmersive smooth motion is what I want. If the Swift has decent color without bad backlight bleeding like I've seen from Asus lightboost monitors in the past (VG278HE), then it will be an instant hit for me. But I'll probably play quite a bit with Lightboost off... because it actually stings my retinas after a bit. Doesn't mean it doesn't look amazing to me.
One thought I'll leave you with though. Even mathematically, I don't think the 120Hz OC monitors are that bad off from Lightboost. They aren't in the same league but they are in a league of their own in terms of color: if the 120Hz Catleap (you may find a 120Hz Qnix hard to find, might not) has 7x the blur of a 1ms Lightboost TN, and a Lightboost TN has essentially zero motion blur... what's 7x almost zero? Still almost zero. I like the OC monitors a lot. The Qnix is prettier, the Catleaps all have a slightly darker strip across the bottom of the screen (not very noticeable and it's there on all S-IPS), but the Catleaps are much easier to hit 120Hz with, and they are glossy. I can't even choose between them, to be honest. I have 1 of each and I don't know which to get rid of to make room for the Swift.
Soon. My friend. Soon.I wish we could pre-order the Swift![]()
Just got an "ultimate pixel perfect" qx2710 (gauranteed to have no dead pixels and minimal bleed) for $330. Can't wait to get this sucker and see if it OCs.
My "ultimate pixel perfect" is indeed a perfect monitor and OCs fine to 120hz (which is a whole different world for gaming). One problem...the monitor just doesn't fit vertically in my desk by about 1/4" which is tragic as I absolutely can't change my desk. I think I was reading the measurements without the stand. This is utterly frustrating, but I think I need to return it. Argh!
Soon. My friend. Soon.![]()
Are there going to be Korean versions of the 4k monitors? Hope they are priced around $300 if they come.
I don't know why people are going crazy about 4K monitors.
Unless of course, they own the new Radeon R9 295X2.
Anyone have any comparisons of the 1080p 120hz smoothness of seiki VS the 1440p 120hz smoothness of korean QNIX?
I heard the 120hz effect of korean QNIX is far from the native 120hz TN panels,
is that also true for the seiki?
Has anyone successfully run a mac mini (2012 w/ mavericks) with this display? I've looked thru some of the posts on apple discussion boards and there are complaints that when their machine comes out of hibernation the display doesn't come to life. Reconnecting the video cable fixes the problem, but thats sort of a hassle. And I think it's specific to macbooks.
Is it good for photo editing?..
The Qnix definitely is good enough for photo editing. Absolutely. The thing is there's variations on the panel/PCB sets that affect how well the panel will overclock. At 60Hz these are generally about the best sRGB monitors for editing under 800 dollars. As you overclock them higher they tend to get dimmer and it sometimes isn't even across the screen. That said I prefer doing *anything* at a higher refresh rate and higher framerate. Even just browsing on the web I must have smooth motion or I start to get irritated.
But, generally speaking, the 2 Matte Qnix's I got from Ecomade Arena on Amazon (AccessoriesWhole on eBay, iirc) were BOTH the best panels I've ever seen. They hit 100% sRGB coverage and the uniformity was staggering. One of them was completely backlight bleed free but had a tiny bit of glow, and the other was the opposite. I had a really hard time choosing between the Qnix and Catleap. I mostly only sold the Qnix because it involved losing less money. The IPS variants like the Overlord and Catleap should have an unfortunate dark strip at the bottom of the screen. It's not a defect its a panel tech. limitation and it's not particularly noticeable. The PLS Qnix will not have any unfortunate or obvious abnormalities anywhere. I did test a glossy Xstar that was pretty different from those, however. It had been damaged slightly in shipping but still worked. It was clearly a different panel/PCB combination altogether although it was a Samsung PLS as far as I know. The thing just acted completely different about overclocking from the Qnix's and it had completely different color characteristics--not nearly as good.
Sorry for the semi-necro. I've read through most of this thread, as well as some other threads, but there aren't many recent updates that I can see. Are these still as overclockable as they were? From what I understand, the new AH-VA panels aren't at all, and actually have more lag, despite advertising 4ms.
So I was thinking about this one, since I don't have a ton of light in my room. Is it still a good buy?
