Took me a week longer than I wanted to get my FT02 and put everything together, but as of the wee hours of this morning the rig is up.
Everything's still running on stock/auto with the exception of a few minor Bios tweaks (AHCI, etc), and will be dealt with later today, but I just wanted to throw up a few admittedly poor glare/flash plagued Nexus One shots before carrying on. Please excuse the clutter in the case, it's nowhere near finished yet as I just wanted to make sure everything was functioning and I'm waiting on my wire saddles anyways. Once I get everything tweaked I'll get some new photos up.
Setup:
CPU: I7 2600K
Mobo: Gigabyte P67A-UD7
RAM: 2x4GB Corsair Vengeance
GPU: XFX 6950
PSU: Corsair AX850
Heatsink - Venomous-X /w Noiseblocker M12-P
Reused parts from old build: 160GB X-25M G2 Intel SSD and 2TB WD Green drive.
Plenty of challenges with the build, but the most important of note is the Venomous-X and the clearance issues regarding the DIMMs. If you use the aftermarket fan holder, it will block the first two DIMM slots and RAM with tall heatspreaders will be affected. Old issue that will persists. I suspected this would be the case but was hoping that it wouldn't become reality.. unfortunately it did. To those considering Vengeance ram or any RAM with tall heatspreaders please keep this in mind. I'll likely be selling off the Vengeance soon and getting something like G.Skill ECO.
The stock wire clips that come with the Ven-X should be fine and give you just enough room, unfortunately I can't use them with the Noiseblocker M12-P due to the rubber grommet corners the fan has. The fan clips have nothing to latch onto.
Setup:
CPU: I7 2600K
GPU: XFX 6950
PSU: Corsair AX850
