Ok, like others, been a while since I've upgraded (from q6600). Upgraded to a retail 2600k and asus max iv gene-z. I'm not sure if I like the efi bios (compared to the classic blue bios) but I loaded optimal defaults and then set the CPU to auto turbo with all cores and XMP for my ram. Saved and called it a day.
In windows, lates version of Core Temp shows the CPU idling at 3.8ghz. Now I'm a stickler for keeping things cool and quiet. The CPU is idling around 45c. My room is about 75 degrees year round. My cooler is the h50 with just one fan exhausting out the back. Case sides are off while I'm tweaking this for the next week. Yes, I'll add the second fan for push pull.
Im not sure why speedstep is not working and down clicking at idle, but I also think my idle temps are a bit high as well.
Any suggestions from fellow gene-z /2600k owners?
