Gaming mostly, some photoshop and minor video editing.
Games include: Starcraft 2, WoW, Left 4 Dead 2, CS1.6/Source, Black Ops, Rift
$1150 not including shipping/tax.
3) Where do you live?
Overland Park, Kansas. I live less than 5 minutes from a Micro Center.
CPU, MOBO, RAM, PSU, GPU, CASE, DVD-ROM, HDD.
None. Just Monitor/Mouse/Keyboard.
6) Will you be overclocking?
I want the ability to, but I dont want it to be the focus of my build. So the answer is yes, but not right away. I hear hitting 4ghz is easy on the 2500k but I would need to upgrade the stock cooler. Let's keep that as a future project.
I have a 22" monitor 1920x res 2ms.
Within this next week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I just want a single videocard for now, with the ability to add a 2nd one for SLi in the future. I have always bought Nvidia because of Digital Vibrance support. Does ATi have a "Digital Vibrance" equivalent these days?
Yes. Windows 7 64 bit.
CPU: i5 2500k $179.99 (Microcenter)
MOBO: ASUS p8p67 PRO $189.99 ( http://www.newegg.com/Product/Produ...131682&cm_re=p8p67_PRO-_-13-131-682-_-Product )
GPU: GeForce GTX 570 $349.99 ( http://www.newegg.com/Product/Product.aspx?Item=N82E16814121412&Tpk=asus gtx 570)
RAM: G.Skill RipJaw X 8gb (2x4GB) DDR3 1600 $104.99 ( http://www.newegg.com/Product/Produ...0231314&cm_re=ripjaw_x-_-20-231-314-_-Product )
PSU: Antec TruePower 750w $119.99 ( http://www.newegg.com/Product/Produ...antec_truepower_tp-750-_-17-371-025-_-Product )
CASE: Cooler Master CM690 $69.99 ( http://www.newegg.com/Product/Product.aspx?Item=N82E16811119215&cm_re=CM690-_-11-119-215-_-Product )
HDD: Samsung SpinPoint F3 $59.99 ( http://www.newegg.com/Product/Produ...185&cm_re=spinpoint_f3-_-22-152-185-_-Product )
DVD-ROM: LG DVD-RW $15.99 ( http://www.newegg.com/Product/Produ...136216&cm_re=LG_DVD-rw-_-27-136-216-_-Product )
Total: $1095.92 Before Tax/Shipping.
