Willsonman
- Jun 11, 2005
Looking at a solution for my case mod issue and am looking at a part that requires 24 volts. is there any way to place a series circuit to get this? Any other way to get 24V?
Putting two molex 0V & 12V pairs in series in an attempt to get 24V is guaranteed to cause a bang.You could be very very lazy and do a probably bad for everything involved ganging together of two 12V sources from the PSU.
No offense intended, but what movax is suggesting is a very good way to (at a minimum) blow a fuse in your power supply.
Using the -12V rail from an older PSU is also not recommended, because the current rating is very low for that rail. The -12V rail was only used for negative signals on things like serial ports, not for actually powering anything.
IMO, your best bet is to actually get a real 24V power supply that can source the kind of current you need.
Yeah I guess it wouldn't work because they have a common ground unlike a battery for example. But what about mains inside your house? You know how you have 220v for your appliances? IIRC they take two 120v lines and combine it into one so I guess it could work that way.You mean two 12V molex from a standard ATX power supply? The problem would be connecting yellow on one to black on the other, thus shorting out the power supply.
There's a world of difference here between your computer PSU and your house mains. As in Westinghouse vs. Edison difference--the power in your computer is DC, while the mains is AC. You're right about how they get 240VAC in your house--there's typically actually two 120VAC lines and a neutral coming into your house. The two AC lines are 180 degrees out of phase, so the voltage difference between the two is 240V.Yeah I guess it wouldn't work because they have a common ground unlike a battery for example. But what about mains inside your house? You know how you have 220v for your appliances? IIRC they take two 120v lines and combine it into one so I guess it could work that way.
But that's completely unrelated to what we're working with here. Except that we're still pushing electrons through metal wires....![]()
It depends on how the electrical sources are built. Batteries and (depending on phase) AC power, yes. Wall-connected DC power supplies...it depends on how their wired. If they're properly isolated, then yes. But I wouldn't count on that being the case for a computer PSU, since the ground on the PSU is often connected to the case ground. It *might* be possible to get 24V using two PSUs, but I wouldn't count on it. I guess you could get a couple of el-cheapo PSUs and try it out. Just wear safety glassesYes I know house mains are are AC while computers are DC but that doesn't mean you can't add up electrical sources in order to increase amperage or voltage.
Yeah because they share a common ground.I have tried it... you get sparks.
The DC-DC converter idea works though. I used a few when I needed -12V at 2.5 amps for some computers at work.
The reason you can "stack" the two circuits in your house is that one is the opposite voltage of the other. For AC, that's the same as being 180 degrees out of phase. The difference (sin(x) - (-1*sin(x) = 2sin(x))gives you twice the voltage difference.My idea would be to emulate that of house wiring where they have 1 common ground and 2 "hot".
So I guess you'd hook up the two 12v molex connectors and then finish the circuit out to the ground.
You say that you can do that with AC because they're 180* out of phase, but wouldn't they be perfectly within phase if they both come from the same panel? My electrician says you take two 10gauge lines, combine the hot and then you'd have 220v. But since they both come from the same panel, I don't see how they'd be out of phase like you're saying.The reason you can "stack" the two circuits in your house is that one is the opposite voltage of the other. For AC, that's the same as being 180 degrees out of phase. The difference (sin(x) - (-1*sin(x) = 2sin(x))gives you twice the voltage difference.
We don't have that same luxury with a DC PSU. If the second rail were -12V, then sure, we could connect the two grounds together and get 24VDC out. But both of the rails are +12V with respect to the same ground. If I'm understanding you correctly, you're suggesting that you could tie the 12V line from one molex connector to the GND line of another molex connector, and that the "12V" line on the second connector would then be at 24V relative to the GND of the first connector. Is that what you're suggesting? If so, please don't try it. Since the 12V lines from both molex connectors come from the same solder pad inside the PSU, and the GND lines also come from a common solder pad, if you connect one 12V line to a different GND line, you're shorting out the PSU.
They may come from the same panel, but they're not the same source. In order to get both 120V and 240V, you have to run three wires into the house: a common neutral and two AC lines, which are 180 degrees out of phase with one another. Those two 120V lines then feed different circuits for most things in your house. Around half the circuits will be on one and half on the other, all of them connected to 120VAC on one end and the common neutral at the other. Where there is a need for 240V, the plug is wired to one 120VAC line on one side and the other 120VAC line on the other. The difference between those two lines gives you 240VAC.You say that you can do that with AC because they're 180* out of phase, but wouldn't they be perfectly within phase if they both come from the same panel? My electrician says you take two 10gauge lines, combine the hot and then you'd have 220v. But since they both come from the same panel, I don't see how they'd be out of phase like you're saying.
Care to share what you did to make it work?I agree... but I figured out another way to do what I want to do and it no longer involves trying to get 24V. Shall I just close the thread?
