texuspete00 said:You have a sqaure plasma? Coooool.
http://www.tasmanav.com.au/pages/DigitalProducts.html
It's the one on the right, and it's not square.
John said:This thread is becoming ridiculous. Really, if you don't have something useful to add to the discussion then don't bother posting at all. If you believe that your 2405FPW supports HD over component, feel free to let us know but don't throw a tantrum.
It is a fact that at least some 2405FPWs don't display HD over component properly. If you're going to contest that, provide evidence.
googleli said:"don't display HD over component properly" meaning having jaggies? If it doesn't support HD, nothing will come up on 1080i at all, just like when you connect a progressive 100Hz tv with component input but without HD support.
The appearance of jaggies is because of the hi rez of full HD 1920X1080 (when using 1:1 ratio) in Dell, which is not present in most LCD TVs or Plasma (which can have resolution as low as 852X480). If in doubt, try to hook it up on a full HD 1920X1080 LCD TV (e.g. the Sharp 45" LCD TV) and see whether the jaggies pop up like Dell.
Then why does 1:1 VGA @ 1360x768 have no jaggies?googleli said:First off, if it doesn't support HD, nothing will come up on 1080i at all, just like when you connect a progressive 100Hz tv with component input but without HD support. That alone defeats the statement "2405FPW has no support for HD".
Second, "don't display HD over component properly" meaning having jaggies? The appearance of jaggies is because of the hi rez of full HD 1920X1080 (when using 1:1 ratio) in Dell, which is not present in most LCD TVs or Plasma (which can have resolution as low as 852X480). If in doubt, try to hook it up on a full HD 1920X1080 LCD TV (e.g. the Sharp 45" LCD TV) and see whether the jaggies pop up like Dell.
Not necessarily - there are a few theories, all we know is that the quality is poor from X360 sources. (I haven't personally tested anything else, but it seems unlikely that it would be a problem with the X360 itself.) There's a loss of quality, and I've got no idea what's responsible for it.i5hawn said:if something isn't HD then it wouldn't be able to show things at 1080i correct?
John said:Not necessarily - there are a few theories, all we know is that the quality is poor from X360 sources. (I haven't personally tested anything else, but it seems unlikely that it would be a problem with the X360 itself.) There's a loss of quality, and I've got no idea what's responsible for it.
googleli has an interesting theory, but 1:1 VGA still looks better than 1:1 720p - and it's not a marginal difference, it's big.
You got it all backwards. Higher resolution provides less jaggies due to more image detail and sharper lines. When using 1:1 you get a "pixel perfect" image. No pixel doubling or stretching of image. 1920x1080 on 1:1 gives a high resolution image with much less jaggies then a 852x480 at 1:1. Its like drawing a picture with a pencil instead of a big brush!
magnetik said:that's a good point. that would explain why the 2 other people in this thread (including myself) that run through a Comcast HD source are so adamant on it supporting HD. The cable box has 1080i native output. Wish we had more people using the 2405fpw through hd cable to give their thoughts.. It seems like most of the ???'s so far are concerning the xbox360.
If for some reason the 2405 scales 480p to 1080i.. and does not in fact support HD, the scalers are the most amazing thing I have ever seen. If so.. they should incorporate them in all non-HD sets.
Windfire said:People mix up "HD" with "HD DVD". HD as it currently exists works at 1080i with Component, DVI and HDMI. Heck, something like 80% of HD TVs are non-HDMI.
Windfire said:This stupid issue will likely result in a very long delay for HD DVD to establish itself or potentially kill it. Think about it. Most HD owners (like myself --50" wide-screen with DVI but no HDMI) are enthusiasts. We are the very people they need as advocates and they will be making our TV's obsolete. Not a good thing to alienate your core early adopters.
Ummagumma said:Of what I have seen so far, I don't think it supports HD over components. But, some claim that it does, and even "heavyweights" like Magnetik, so it might be that some revisions support it. I am not sure. But, should it support HD over components, then this is how a HDTV signal at 1080i looks like: from HDTV Pub Lets hope I am wrong!
I hope I get an answer and some footage that shows the difference between a still picture of 720p and 1080i of HDTV. That is a resolution change of more then double! 2 073 600 vs 921 600 = 1 152 000 pixels!!!
Ummagumma said:What has puzzled me most in the whole discussion is the little difference between 720p and 1080i. On some of the games I can understand it, since they are natively 720p and are upscaled to 1080i. It would make a difference, but minor compared to native 1080i. The game above, NFS: MW has native support for 1080i. When looking at the pictures, the PC had much higher detail. Look at the background especially and also the rest of the picture. Notice how much the pc pictures increases level of detail the higher resolution compared to the components!
Ummagumma said:Looks like your wish about comparing with alternate sources to the xbox is about to come true!
link
A comparison between PC -> Components -> 2405fpw and PC -> VGA -> 2405fpw both running at 1920x1080 would definitly convince me in either way! If there is no loss of detail between such comparison, how can the 2405fpw NOT be HD through components, and if there is a loss of detail, how can it then be HD through components?
1080 downscaled to 480 and then upscaled to 720/1080 is one thing and there are many ways to explain difference in PQ. But, true 1080 vs. downscaled then upscaled 1080 would be easy to see the difference IMO! If level of detail is the same, then I am convinced, and if not, then I am convinced there too!!!!!
magnetik said:wow.. navyh17 got a response from John Carmack?!?!
From a pixel-count perspective, the 1080i supports better spatial resolution than a 720p HDTV display. In fact, while a 1080i supports a total pixel count of 2.07 million pixels, a 720p display supports only 0.92 million pixels. This means that if you want to display a 1080i signal on a 720p screen, you will lose 55.6% of pixels information. link
revs said:What looks better - a 2405/360 connected via VGA or Component?
The verdict seems to be Component - even though we are unsure it does HD over Component?
Cool. If VGA was better I would have to have a VGA switcher as ive git VGA going into my 2405 already.NavyH16 said:That's what I've come to decide (just took back teh VGA cable). And yep..Carmack. His response didn't really settle much, but it sure was interesting to hear from teh source.
Navy
