LAGRUNAUER
- Dec 7, 2006
The discoloration you see in the bottom of the screen is a possible landing issue. If the landing controls on the OSD do not correct the problem, then it has to be adjusted at the Sony Service Center in San Diego.
There are many "quick fix" options such as opening the monitor and placing a small magnet on the CRT frame right where the color discoloration is present, or using the degauss feature, but I do not recommend these options as you only will be puting a "band aid" to the problem, and not fixing it.
Since 2001, I have sold hundred of these monitors to many satisfied eBay customers, and I can tell you with 110% certainty that the GDM-FW900, along with the F520, the C520 and the CPD-G520P, were the best CRT monitors Sony ever made, with the FW900 being the king of all them all.
Hope this helps!
Luis A. Grunauer, Jr.
Unkle Vito!
Hope this helps!
Unkle Vito!
