24" Widescreen CRT (FW900) From Ebay arrived,Comments.
Discussion in 'Displays' started by mathesar, Sep 13, 2005.
  1. Dick Johnson
    Dick Johnson [H]Lite
    69
    Sep 27, 2016
    I copied the OP and posted it to another forum that I hang out on, as if I just bought this monitor recently.
    People are losing their minds over it.
  2. jka
    jka n00b
    59
    Feb 16, 2017
    Modern as in "can play latest games reasonably well". GTX480 would be a little stretch then but could be considered still modern I guess. But feel free to include old cards too if you want, I am building a Geforce 7 rig right now so there is plenty of love for the older cards too.
  3. Strat_84
    Strat_84 Limp Gawd
    247
    Jul 16, 2016
    What forum is it ? I want to have fun too. :D
  4. CommandoSnake
    CommandoSnake n00b
    50
    Aug 10, 2018
    me too
  5. christpunchers
    christpunchers Limp Gawd
    465
    Dec 26, 2006
    If anyone is interested in selling mint-condition FW900s with AG still intact, please PM me. Thanks.
  6. CommandoSnake
    CommandoSnake n00b
    50
    Aug 10, 2018
    ^I'll pay 1.5x whatever he's offering :D
  7. christpunchers
    465
    Dec 26, 2006
    Lol. Ok let’s start a bidding war.
  8. XoR_
    XoR_ Gawd
    596
    Jan 18, 2016
    Radeon cads do 8bit dithering and can even correct gamut if you have EDID emulator - unfortunately white point is not set properly and Radeon gamut correction can only work with data from EDID and behaves strangely when white point is not exactly where sRGB spec says it should be :(
    Though of course gamut is close to sRGB enough for it not be an issue and for movies where it actually matter gamut, gamma, etc. correction is best done with madVR <- as is everything related to watching movies on PC, best piece of code evar, especially for SD movies (y)
    BTW. This is ridiculous that NV just doesn't add ability to load ICC profile. It + dithering (which these cards can do, they just won't) would solve all issues related to calibration ... :mad:
  9. igsux3
    igsux3 [H]Lite
    107
    Oct 23, 2014
    Hi guys,
    I'm thinking about upgrading my PC and so I would like to upgrade my 980Ti which we all know is the last DVI-I card.
    Are there any better alternatives to DeLOCK 62967 ? Of course I'm going to use WPB and custom ICC profile...
  10. Aktan
    Aktan [H]Lite
    121
    Dec 31, 2017
    The Delock 87685 is better or if you are in USA, the SUNIX DPU3000.
  11. popalazarou
    popalazarou n00b
    20
    Mar 10, 2016
    im looking at upgrading soon too. I really want to keep my recently purchased fw900. Is there a way i can use a 2080ti with it. Interestingly were in the same ballpark, although i reside in the uk. I did notice the evga 1080ti has a dvi out on it, (if the image is correct). But after doing light research i saw that i may be able to use the displayport to connect to my fw900. Is there a possibility of using a 2080 displayport or hdmi to connect my monitor? Which is best and possibly available in the uk. I saw these but i am unsure of the quality DELL and HP .I could really do with some expert advice as the way to approach it correctly. Thanks in advance
  12. Enhanced Interrogator
    Enhanced Interrogator Gawd
    848
    Mar 23, 2013
    popalazarou If you're getting a 2080Ti, then you want the Sunix DPU3000 so you can run crazy shit like 2304x1440@85hz.
    Since you're in the UK, it may be easier to find the Delock version. They all use the Synaptics VMM2322 chip.
  13. popalazarou
    popalazarou n00b
    20
    Mar 10, 2016
    i can see one Sunix DPU3000 on amazon uk so im pretty chuffed, It does look precisely what im after. this sounds nuts. I was a little skeptical of my recent fw but i have a reasonable calibration and brightness that im happy with ( perfect blacks). Seems even better than my last one and seems in very good condition so i may now go down this road. Witcher 3 cyberpunk metro tomb raider would be pretty amazing at 2304x1440 @85hz. Does it come with software ? i never used one before. https://www.amazon.co.uk/gp/offer-listing/B00M89Q3FC/ref=dp_olp_new?ie=UTF8&condition=new
  14. popalazarou
    popalazarou n00b
    20
    Mar 10, 2016
  15. popalazarou
    popalazarou n00b
    20
    Mar 10, 2016
  16. Enhanced Interrogator
    848
    Mar 23, 2013
    I don't remember which Delock adapter had the Synaptics chip.
    Derupter do you remember which one it was? This one looks like it may also have the chip.
  17. Aktan
    Aktan [H]Lite
    121
    Dec 31, 2017
    I listed it above, as it looks exactly like the SUNIX, but I could be wrong.
    Edit: I looked at Delock's website and it's the correct one.
  18. Aktan
    Aktan [H]Lite
    121
    Dec 31, 2017
    These are just plug and play. There is no software.
  19. Aktan
    Aktan [H]Lite
    121
    Dec 31, 2017
  20. Enhanced Interrogator
    848
    Mar 23, 2013
    Whoops, I missed that post. Yeah, the Delock 87685 is the same as the Sunix and might be cheaper in the UK.
    Though that adapter popalazarou linked might be worth looking into, now that Nividia's cards have USB-C out. It's also a splitter, so there's a possibility it's using the synaptics chip.
  21. Derupter
    Derupter Limp Gawd
    147
    Jun 25, 2016
    This is the 87730,i just asked Delock which chipset is inside it,if VMM2322 it will be very good for that price.
    Looking amazon uk,if you don't need pixel clock over 330-340 MHz(1920x1200 96Hz is around 322 MHz),the best is this:
    https://www.amazon.co.uk/Plugable-A...=1539159780&sr=1-5&keywords=Plugable+USBC-VGA
    Other USB-C solutions are:
    Delock 62994 with Realtek RTD2169U
    Delock 63924 with IT6562 and 10 bit DAC
    Both have 360 MHz input bandwidth but no one tested them,so we don't know how can the DAC go up
    If you need more,like 2304x1440 80 Hz or extreme pixel clock the only solutions are:
    Delock 87685
    Sunix DPU3000-D3 (D2 is for cards with mini Displayport)
    Both with Synaptics VMM2322 chipset
    EDIT:
    On Amazon UK there is also the adapter discovered by CommandoSnake
    https://www.amazon.co.uk/Active-Adapter-Benfei-Converter-Gold-Plated/dp/B01KLKQN9U
    tested up to 1920x1200 96 Hz,for that price it's very interesting,the only problem is that it need to be set to YCbCr instead RGB,i don't know if that can cause problem with some configurations
  22. igsux3
    igsux3 [H]Lite
    107
    Oct 23, 2014
    Thanks for all the replies, so it's Delock 87685 or Sunix DPU3000-D3. Both are more expensive than what I paid for each of my FW900 :confused: I'll stick to Delock 87685 as it's available in my country. Even though it's a splitter, does it work as normal DisplayPort to VGA converter? So just one output from Nvidia Control Panel just like if it was single VGA output?
  23. Derupter
    Derupter Limp Gawd
    147
    Jun 25, 2016
    They call it splitter because it has multiple outputs but works like all other adapters
    If you need more than 1920x1200 96Hz those two are the only we know,but keep in mind that some users have had minor problems with Synaptics chip,at least with Sunix adapter.
    So if your new card come with USB-C output and you don't need super high resolutions, consider a more cheap solution like Plugable USB-C to VGA or Delock 62796.
  24. Enhanced Interrogator
    848
    Mar 23, 2013
    Yeah, it even passes through the monitor's EDID to the GPU.
  25. Aktan
    Aktan [H]Lite
    121
    Dec 31, 2017
    Because it's a splitter, you can actually connect multiple monitors too! Though I have not tried that myself, lol.
  26. FepMeister
    FepMeister n00b
    2
    Oct 10, 2018
    I have small semi off topic question,I bought Eizo T57S CRT,it have nice Trinitron display and its spec is 1280 x 1024 at 85 Hz.I have Quadro P620 gpu,it have only mini displayport output.I bought cheap Akasa miniDisplayPort > VGA adapter and using Win 10 I could only run 60 Hz not matter what resolution.
    I installed Win 7 and somehow I got option to set it to 75 Hz,that helped alot with flicker but its still not 85 Hz.Any idea how to get 85 Hz? I dont know if it is the VGA adapter limitation or software thing.
  27. Derupter
    Derupter Limp Gawd
    147
    Jun 25, 2016
    Try with CRU:
    https://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU
    Read the instructions,set a resolution (detailed or standard or both),with detailed you have more settings (with this use CRT timing)
    After this restart the driver with the integrated utility
    Your monitor has these limits:
    30 to 92 kHz horizontal frequency
    50 to 160 Hz vertical frequency
    Usually displayport adapters are limited only by pixel clock,if you set a resolution over max pixel clock it simply doesn't appear on Windows control panel
    You can do without problems 1280x1024 85 Hz or example 1024x768 110 Hz or 640x480 160 Hz
    FepMeister likes this.
  28. Derupter
    Derupter Limp Gawd
    147
    Jun 25, 2016
    I received a reply from Delock, no Synaptics chipset inside 87730 splitter.
    Enhanced Interrogator likes this.
  29. christpunchers
    465
    Dec 26, 2006
    Those of you with good graphics cards: how do the recent Nvidia cards from the last 2-3 generations do when it comes to supersampling/downsampling? I'm looking to run games in 1440p or 4k and downsampling to 1920x1200, but I've never been able to get Nvidia's downsampling from the control panel to work properly.
  30. CommandoSnake
    CommandoSnake n00b
    50
    Aug 10, 2018
    It should work fine. It'll be 4x your native resolution at most.
  31. christpunchers
    465
    Dec 26, 2006
    But I’ve never got DSR to work.
  32. Enhanced Interrogator
    848
    Mar 23, 2013
    It's a bit of a headache for CRT monitors. If you want to downscale to 1200p, you have to delete all higher resolutions with CRU, like 2304x1440.
    And even then, some games won't detect the DSR resolutions. Recently, I found Mega Man 11 doesn't detect the DSR resolutions for some reason.
  33. 3dfan
    3dfan [H]Lite
    75
    Jun 2, 2016
    on a GTX 980 TI with the FW900, i have tested adding a DSR 4x resolution downsampling to 1920 x 1200. with a result of 4096 x 3072.
    what i do is to make windows believe 1920 x 1200 is the monitor native resolution (tested on windows 10 pro 64bit 1709), for that, i create the resolution with CRU (tested with custom resolution utility version 1.4.1) from the detailed resolutions, using automatic CRT standard, and moving the resolution to the top with the up arrow, so it seems the top resolution on that list will be what windows believes is tha native one, then restart the PC, and now you check that nvidia control panel lists 1920 x 1200 as native, then create DSR 4x and thats it.
    now if what you want is 4K known as 3840 x 2160, i created 2560 x 1440 with same procedure mentioned, in DSR set to 2.25x, (FW900 supports 1440p up to 2560 x 1440 75hz 16:9 and 2560 x 1600 16:10 68hz without the need of DSR, at least with the gtx 980 TI)
    spacediver and CommandoSnake like this.
  34. spacediver
    spacediver 2[H]4U
    2,455
    Mar 14, 2013
  35. guiddqd
    guiddqd n00b
    7
    Sep 6, 2018
  36. Strat_84
    Strat_84 Limp Gawd
    247
    Jul 16, 2016
    Well, if your video card has a DVI-I output it should work. But it's hard to tell without knowing the exact model you have, there might be custom manufacturer cards not featuring it but still using connectors with the DVI-I keyed connections instead of the DVI-D ones.
    Fool-proof question: Did you think about selecting input 2 on the monitor switch when plugging that cable ?
  37. guiddqd
    guiddqd n00b
    7
    Sep 6, 2018
    Yes ;) Ive made foolish mistakes like this before but not this time!
    Its this model:
    https://www.asus.com/us/Graphics-Cards/GTX650TIBDC2OC2GD5/
    Edit: Ok, a message appeared with 'out of sync' when I turned off the pc but it doesnt come back on I dont know what else was written. I put 1024 as the resolution using hdmi before trying though so I dont get it.
  38. CommandoSnake
    CommandoSnake n00b
    50
    Aug 10, 2018
  39. guiddqd
    guiddqd n00b
    7
    Sep 6, 2018
    Ok it works now. Thanks a lot!
    Edit: After some testing, I see that 1024 is the highest resolution that can support 144hz. Normally the fw900 can go higher than that.
    Is it limited because of the gpu? Or the cable?
  40. CommandoSnake
    CommandoSnake n00b
    50
    Aug 10, 2018
    Cable shouldn't be an issue. It's probably the GPU's 400mhz RAMDAC limit. You could try overclocking it but I don't know how. If you find out let me know.
