Hey all
I found an FW900 for 330 I'm not sure if its worth this price or not. It's also a 2 hour drive to get it. I might be able to negotiate a little but probably not much.
My planned usage is just gaming.
Any opinions?
Mine is sick: it will flash green for several seconds when I turn it on, and sometimes, it will stay like that, and shut itself off after a few seconds. Looks like I'll be making a trip to the dump, soon.
Im done with FW900's. Far too heavy and I'm not a gamer or DVD movie viewer on my computer.
Both my 21" NEC FB2111SB monitors suffice - 1 white 1 black (backup monitor)
As good if not better than the FW900 except for the widescreen.
so if i come across any good deals locally I shouldn't let you know, right?
Zeos! How did you get 10 bit color working? I know the CRT supports it, but what kind of video card did you use? Share!!
24-bit color is what the monitor will produce (3 color channels, 8-bits per channel). That's 16,777,216 colors.Ati 4890. I presume you are confused. 32bit color is what the monitor will reproduce. VIDEOS on the other hand have only recently been able to be encoded in 10-bit color with special H264 codecs.
As far as I know, there is no way to put the FW900 into 30-bit (Deep Color) mode. It maxes out at 24-bit (Tue Color) mode. Playing 30-bit content on a FW900 will result in it being down-sampled to 24-bit by the time you see it.
It's not the guns or the phosphor I'm concerned with, it's the internal signal processing and mode-setting hardware within the CRT.There's no reason why, for example, the RED gun should only be able to fire 256 distinct voltages.
A straight up "dumb" analog device will work as you described. A "smarter" CRT with some actual brains in it will likely have a tendency to throw an "out of range" error if you attempt to feed it a mode it doesn't recognize.
